Server and Process Not Responding [RESOLVED]
Postby ruinerXIII » Tue May 28, 2013 10:38 pm
Problem Description: The server will load initially, although often part of the GUI won't load. After the initial load, sometimes I will be able to play music for a bit before it stops loading mid-song, other times I won't be able to play anything. On reload, the server will time out. From the host computer using the localhost address, the server also times out. If I try to restart the service, the Administrative Services panel shows the service as "Stopping" and does not change. The system tray icon will respond normally, although it will show the process as not running and will not allow me to start it.
Troubleshooting Steps: Reboots sometimes temporarily resolve the issue, as noted above, but only for a brief period. I have also tried reinstalling Subsonic, but that did not help.
Playback Application and version: Chrome/Minisub (Minisub just reports "bad server")
Subsonic Version: 4.8 (build 3434)
Server Version: jetty-6.1.x, java 1.7.0_21, Windows 8 (79.8 MB / 134.5 MB)
Hardware Platform: Windows 8
Java Memory Limit: 512
Problem Filename: N/A
Output from ffmpeg -i: N/A
Last ten log file lines:
[5/28/13 6:30:04 PM EDT]   INFO   DaoHelper   Checking database schema.
[5/28/13 6:30:12 PM EDT]   INFO   DaoHelper   Done checking database schema.
[5/28/13 6:30:12 PM EDT]   INFO   PlayerDao   Deleted 1 player(s) that haven't been used after Fri Mar 29 18:30:12 EDT 2013
[5/28/13 6:30:13 PM EDT]   INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Wed May 29 15:00:00 EDT 2013
[5/28/13 6:30:13 PM EDT]   INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue May 28 18:35:13 EDT 2013
[5/28/13 6:34:35 PM EDT]   INFO   NetworkService   Successfully forwarding port 4040 and port 4443.
[5/28/13 6:35:13 PM EDT]   INFO   PodcastService   Starting scheduled Podcast refresh.
[5/28/13 6:35:13 PM EDT]   INFO   PodcastService   Completed scheduled Podcast refresh.
[5/28/13 6:35:25 PM EDT]   INFO   VersionService   Resolved local Subsonic version to: 4.8
[5/28/13 6:35:25 PM EDT]   INFO   PlayerDao   Created player 1.
[5/28/13 6:35:29 PM EDT]   INFO   VersionService   Resolved latest Subsonic final version to: 4.8
[5/28/13 6:35:29 PM EDT]   INFO   VersionService   Resolved latest Subsonic beta version to: 4.7.beta3
ruinerXIII
Re: Server and Process Not Responding [RESOLVED]
Postby ruinerXIII » Wed May 29, 2013 11:48 pm
Update: Deleting the database file, then uninstalling and reinstalling seems to have resolved the issue.
ruinerXIII
