Recently Added music will not refresh or add to database
Postby rbotboy » Thu May 30, 2013 12:39 pm
Here is the error .. Plz help. I cannot add new music, refresh list or play new music. Thank you.
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]
Java version Oracle Corporation 1.7.0_21
Server jetty-6.1.x
Memory Used 78 of 145 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.MediaFileDao.getNewestAlbums(MediaFileDao.java:209)
at net.sourceforge.subsonic.service.MediaFileService.getNewestAlbums(MediaFileService.java:271)
at net.sourceforge.subsonic.controller.HomeController.getNewest(HomeController.java:160)
at net.sourceforge.subsonic.controller.HomeController.handleRequestInternal(HomeController.java:96)
at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:47)
Caused by: java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type=? and present order by created desc limit ? offset ?]
... 64 more
rbotboy
Re: Recently Added Music will not refresh and add to databas
Postby rbotboy » Fri Jun 28, 2013 4:27 pm
Ok, figured it out. Had to re-build my database and made sure that my shared folders looked as follows: k:\music and k:\movies. The "\" was missing and now everything has re-populated and works. :D
rbotboy
Re: Recently Added music will not refresh or add to database
Postby umfb19 » Fri Jun 28, 2013 7:53 pm
How did you "rebuild" your database? I'm having the same issue. Added files earlier this week... still not showing up. My file reads he way you show it, i.e. K:\Music, etc. And I've scanned media folders and I've cleaned up the database, both under settings... still not showing up.
I've never had this problem... have over 10k in files already in here that work... just started this week. And they are separate files, so the file isn't corrupt or anyting.
umfb19
Users browsing this forum: Google [Bot] and 28 guests
