[Android] Can't View Movies on Root Folder in App
Postby ZeroManArmy » Thu May 30, 2013 5:35 pm
Hey Everyone,
For some reason on the Android app I am unable to see the Movies that are on the root of the folder. I can when I see them when I use the Web interface but not on the android app. Any reason why?
I also would like to know how to stop multiple players from showing up everytime I login. It's driving me insane. Each time a user logs in a new player is made... What can I do to stop this?
ZeroManArmy
Re: [Android] Can't View Movies on Root Folder in App
Postby GJ51 » Thu May 30, 2013 9:02 pm
All files should be in folders - not in any root media directory.
There isn't anything you can do about the multiple players, it's part of the design an allows you to do multiple configurations for each user and/or device.
Not elegant - but very flexible. Newer versions of Subsonic will auto-clean unused players periodically. Instructions for bulk removal of player have been posted elsewhere in the forum.
Postby ZeroManArmy » Fri May 31, 2013 2:53 am
Even when my movies are in a folder (I:\Movies) they still do not appear in the android app....
ZeroManArmy
Postby GJ51 » Fri May 31, 2013 3:08 am
What format are your movies in?
Do they appear in the desktop browser?
Postby gurutech » Fri May 31, 2013 3:17 am
If I:\Movies is the path you entered in Subsonic, it won't show them. You need to point to I:\Movies, and then put your movies in a subfolder if I:\Movies.
I have mine split with /Videos/TV and /Videos/Movies, with /Videos as my "path" in Madsonic.
gurutech
Postby GJ51 » Fri May 31, 2013 3:44 am
Yes indeed - I thought I explained that earlier ...
If the root folder is I:\Movies then each movie's files need to be inside it's own folder.
So, in Subsonic under Settings/Media folders, you enter:
I:\Movies
Then each movie is then place in it's own folder,
e.g.
I:\Movies\Top Gun\TOPGUN.mp4
The android app will not read any files placed in a root folder that is listed under Settings/Media Folders
Historically, it has been demonstrated that many folders with a relatively small number of files in each folder significantly improves performance over having a small number of folders with a large number of files in each folder. It just makes the db run faster and improve overall performance.
Not too mention it helps keep your storage better organized.
Nice catch Gurutech.
Postby ZeroManArmy » Fri May 31, 2013 3:45 am
GJ51 wrote:What format are your movies in?
Several formats. All show up in the Browser.
ZeroManArmy
gurutech wrote:If I:\Movies is the path you entered in Subsonic, it won't show them. You need to point to I:\Movies, and then put your movies in a subfolder if I:\Movies.
I'm a tad lost with what you're trying to say.
ZeroManArmy
Postby GJ51 » Fri May 31, 2013 3:59 am
The individual files need to go into another folder one layer down.
/Movies/movie.mp4 - will not show the file.
/Movies/comedy/movie.mp4 - will.
Postby ZeroManArmy » Fri May 31, 2013 4:16 am
GJ51 wrote:Yes indeed - I thought I explained that earlier ...
I:\Movies
e.g.
That's such a messy file structure... There has to be a fix.
ZeroManArmy
Postby ZeroManArmy » Fri May 31, 2013 4:26 am
I see what your saying. Too bad it makes the Web UI look like crap. The nav bar on the left.
ZeroManArmy
Postby ZeroManArmy » Fri May 31, 2013 6:29 pm
Now that I got this issue fixed, my phone won't play any movies. It will play TV just fine just no movies.
ZeroManArmy
