Internal Error
Internal Error
Postby coldhardcash » Sat Jun 01, 2013 12:17 am
I am getting the following error on the left-nav side of the subsonic web server home page. Also getting an error when trying to access library from my mobile device.
OS - Win 7 x64
Subsonic - v4.7 (v4.6 works fine, same issue with v4.8)
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]
Java version Oracle Corporation 1.7.0_21
Server jetty-6.1.x
Memory Used 43 of 72 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
at net.sourceforge.subsonic.dao.MediaFileDao.getMediaFile(MediaFileDao.java:58)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:103)
at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:145)
at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:61)
at net.sourceforge.subsonic.controller.LeftController.getMusicFolderContent(LeftController.java:220)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:142)
Caused by: java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]
... 65 more
coldhardcash
Re: Internal Error
Postby coldhardcash » Sat Jun 01, 2013 12:27 am
Additional data after a restart. Looks like the database may be the culprit. Suggestions on how to fix this?
[5/31/13 7:20:11 PM CDT] INFO DaoHelper Checking database schema.
[5/31/13 7:20:26 PM CDT] INFO Schema47 Database table 'media_file' not found. Creating it.
[5/31/13 7:20:26 PM CDT] ERROR DaoHelper Failed to initialize database.
[5/31/13 7:20:26 PM CDT] INFO VersionService Resolved local Subsonic version to: 4.7
[5/31/13 7:20:27 PM CDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Sat Jun 01 01:00:00 CDT 2013
[5/31/13 7:20:27 PM CDT] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Fri May 31 19:25:27 CDT 2013
[5/31/13 7:20:30 PM CDT] INFO NetworkService Successfully forwarding port 4040.
[5/31/13 7:24:37 PM CDT] INFO VersionService Resolved latest Subsonic final version to: 4.8
[5/31/13 7:24:37 PM CDT] INFO VersionService Resolved latest Subsonic beta version to: 4.7.beta3
coldhardcash
Re: Internal Error
Postby gurutech » Sat Jun 01, 2013 12:40 am
Stop the Subsonic service.
Make a backup of your db folder within the subsonic folder (name it something like "backup db".
Restart the service, and it will rebuild a new database.
gurutech
Re: Internal Error
Postby coldhardcash » Sat Jun 01, 2013 1:42 am
Thanks for the response. I went into the subsonic folder (under program files) and the only things are one folder 'log' and then subsonic files. I am not finding any database folder or files.
Is there another directory hidden somewhere?
coldhardcash
Re: Internal Error
Postby coldhardcash » Sat Jun 01, 2013 1:47 am
Nevermind, I found the correct subsonic folder (under root). That seemed to have worked. Thanks!
coldhardcash
