Streaming stops before end of song
Postby slaptoast » Mon Jun 03, 2013 6:54 pm
Problem Description: Certain files cause the server to error and stop streaming, service stays up,
Troubleshooting Steps: Listen to a song, find where it crashes, listen again, song crashes at the same spot
Playback Application and version: standard website, Jamstash, silversonic, they all seem to crash at the same spot
Subsonic Version: Version 4.8 (build 3434) – April 17, 2013
Server Version: Server jetty-6.1.x, java 1.7.0_21, Windows Server 2008 R2 (52.9 MB / 77.6 MB)
Hardware Platform: Windows Server 2008 R2
Java Memory Limit: 800MB
Problem Filename: Nine Inch Nails - The Fragile - Left - 02 - The Day The World Went Away.mp3 (this one fails right away, plenty of others fail at other points)
Output from ffmpeg -i:
  libavutil    51. 11. 0 / 51. 11. 0
  libavcodec   53.  9. 0 / 53.  9. 0
  libavformat  53.  6. 0 / 53.  6. 0
  libavdevice  53.  2. 0 / 53.  2. 0
  libavfilter   2. 27. 3 /  2. 27. 3
  libswscale    2.  0. 0 /  2.  0. 0
  libpostproc  51.  2. 0 / 51.  2. 0
[mp3 @ 01BFCBA0] Header missing
[mp3 @ 01BF9E00] max_analyze_duration 5000000 reached at 5015510
[mp3 @ 01BF9E00] Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from 'Nine Inch Nails - The Fragile - Left - 02 - The Day The Wor
ld Went Away.mp3':
  Metadata:
    artist          : Nine Inch Nails
    title           : The Day The World Went Away
    track           : 2
    album           : The Fragile
    disc            : 1/2
  Duration: 00:04:37.21, start: 0.000000, bitrate: 127 kb/s
    Stream #0.0: Audio: mp3, 44100 Hz, stereo, s16, 128 kb/s
Last ten log file lines:
[2013-06-03 13:24:55,409] INFO PlayQueueInputStream - admin listening to "The Fragile - Left\Nine Inch Nails - The Fragile - Left - 02 - The Day The World Went Away.mp3"
[2013-06-03 13:24:55,440] WARN RESTFilter - Error in REST API: EofException
org.mortbay.jetty.EofException
   at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:760)
   at org.mortbay.jetty.AbstractGenerator$Output.blockForOutput(AbstractGenerator.java:546)
   at org.mortbay.jetty.AbstractGenerator$Output.flush(AbstractGenerator.java:567)
   at org.mortbay.jetty.HttpConnection$Output.flush(HttpConnection.java:907)
   at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:628)
   at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:575)
   at net.sourceforge.subsonic.io.RangeOutputStream.write(RangeOutputStream.java:143)
   at net.sourceforge.subsonic.controller.StreamController.handleRequest(StreamController.java:221)
   at net.sourceforge.subsonic.controller.RESTController.stream(RESTController.java:1128)
   at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Unknown Source)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
   at net.sourceforge.subsonic.security.RESTRequestParameterProcessingFilter.doFilter(RESTRequestParameterProcessingFilter.java:109)
   at net.sourceforge.subsonic.filter.RESTFilter.doFilter(RESTFilter.java:55)
Caused by: java.io.IOException: An established connection was aborted by the software in your host machine
   at sun.nio.ch.SocketDispatcher.write0(Native Method)
   at sun.nio.ch.SocketDispatcher.write(Unknown Source)
   at sun.nio.ch.IOUtil.writeFromNativeBuffer(Unknown Source)
   at sun.nio.ch.IOUtil.write(Unknown Source)
   at sun.nio.ch.SocketChannelImpl.write(Unknown Source)
   at org.mortbay.io.nio.ChannelEndPoint.flush(ChannelEndPoint.java:166)
   at org.mortbay.io.nio.SelectChannelEndPoint.flush(SelectChannelEndPoint.java:208)
   at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:693)
   ... 69 more
[2013-06-03 13:24:55,830] WARN RESTFilter - Error in REST API: EofException
   ... 69 more
slaptoast
