Reset some data
Reset some data
Postby dimaraja » Mon Jul 14, 2008 10:41 pm
Hello All,
What is the code as it is not available through the web admin, to reset to zero:
- Newest
- Highest rated
- Most frequently played
- Most recently played
According to this topic
http://forum.subsonic.org/forum/viewtopic.php?t=1127&highlight=reset some stats can be set to zero through:
http://localhost/subsonic/db.view by running the following code:
update user set bytes_streamed=0, bytes_downloaded=0, bytes_uploaded = 0
Kind regards
dimaraja
Postby sindre_mehus » Tue Jul 15, 2008 7:52 am
The relevant tables for that are music_file_info and and user_rating.
Postby dimaraja » Wed Jul 16, 2008 3:37 am
Thank you Sindre for everything.
Cheers!
dimaraja
