Help with roku 3
Help with roku 3
Postby rainydal74 » Fri Jun 07, 2013 12:23 am
I downloaded the channel and added the subsonicTV lite. I configured the Roku channel with the subsonic address.... and I can see the files, I can scroll through them. However, it wont play, when I select play it says "retrieving" then goes back to the menu screen.
do you have any ideas to help me please? Thanks
rainydal74
Re: Help with roku 3
Postby rainydal74 » Fri Jun 07, 2013 12:32 am
well... I just bought the $5 per year subscription thinking it could be the difference between Lite & Pro... but that didn't work either. It lists the show, when I hit play it says retrieving and goes back to menu. :( not fun.
please help thanks
rainydal74
Postby daneren2005 » Fri Jun 07, 2013 1:14 am
I'm not sure the developer of the Roku channel is active here...
Postby rainydal74 » Sun Jun 09, 2013 3:09 am
I thought the problem was that I needed the update for the software... but it isn't. so now im wondering if it is the .avi format?
rainydal74
