Video Streaming
Video Streaming
Postby cyris69 » Tue Jun 11, 2013 6:05 pm
Hello all, I've been searching around on the forums here to better understand how to properly stream my video archive.
I have my music area up and running perfectly with Subclient and by far the easiest solution has been subsonic. I just paid for a year of premium to get the extra perks including video streaming.
My internet specs are 120Mbits down 20Mbits up
I am an IT graduate but new to DLNA and media streaming so this is a bit complex for me understanding transcoding. I am using the default settings for transcoding, most of my files are mp4 or mkv. When I do select a movie to stream in Subclient I get a black box and nothing happening. I RDP into my server I have running at home and the CPU is nearly maxing so I assume transcoding is happening but no matter how long I want nothing seems transmitted.
My server box is running windows 7, dul core 3,6ghz i5, 6gb ddr3, standard onboard graphics from intel chip.
Does anyone here have command lines that I can try? I attempted replacing flv with mp4 and then restarting subsonic but nothing changed cpu usage was a tiny different. Now I haven't tested streaming from LAN.
Thanks in advanced!
Version 4.8 (build 3434) – April 17, 2013
Server jetty-6.1.x, java 1.7.0_17, Windows 7 (45.1 MB / 101.1 MB)
013-720>ffmpeg -i dark.skies.2013.720p.bluray.x264-sparks.mkv
ffmpeg version N-31653-gfaa3381, Copyright (c) 2000-2011 the FFmpeg developers
  built on Jul 28 2011 01:57:12 with gcc 4.6.1
  configuration: --enable-gpl --enable-version3 --enable-memalign-hack --enable-
runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libo
pencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --
enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger
--enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enabl
e-libx264 --enable-libxavs --enable-libxvid --enable-zlib
  libavutil    51. 11. 0 / 51. 11. 0
  libavcodec   53.  9. 0 / 53.  9. 0
  libavformat  53.  6. 0 / 53.  6. 0
  libavdevice  53.  2. 0 / 53.  2. 0
  libavfilter   2. 27. 3 /  2. 27. 3
  libswscale    2.  0. 0 /  2.  0. 0
  libpostproc  51.  2. 0 / 51.  2. 0
[matroska,webm @ 019A9D40] max_analyze_duration 5000000 reached at 5002000
[matroska,webm @ 019A9D40] Estimating duration from bitrate, this may be inaccur
ate
Input #0, matroska,webm, from 'dark.skies.2013.720p.bluray.x264-sparks.mkv':
  Duration: 01:37:08.69, start: 0.000000, bitrate: 1536 kb/s
    Chapter #0.0: start 0.000000, end 261.470000
    Metadata:
      title           : 00:00:00.000
    Chapter #0.1: start 261.470000, end 502.210000
    Metadata:
      title           : 00:04:21.470
    Chapter #0.2: start 502.210000, end 883.716000
    Metadata:
      title           : 00:08:22.210
    Chapter #0.3: start 883.716000, end 1132.131000
    Metadata:
      title           : 00:14:43.716
    Chapter #0.4: start 1132.131000, end 1474.014000
    Metadata:
      title           : 00:18:52.131
    Chapter #0.5: start 1474.014000, end 1792.916000
    Metadata:
      title           : 00:24:34.014
    Chapter #0.6: start 1792.916000, end 2188.144000
    Metadata:
      title           : 00:29:52.916
    Chapter #0.7: start 2188.144000, end 2432.430000
    Metadata:
      title           : 00:36:28.144
    Chapter #0.8: start 2432.430000, end 2740.404000
    Metadata:
      title           : 00:40:32.430
    Chapter #0.9: start 2740.404000, end 3134.548000
    Metadata:
      title           : 00:45:40.404
    Chapter #0.10: start 3134.548000, end 3581.244000
    Metadata:
      title           : 00:52:14.548
    Chapter #0.11: start 3581.244000, end 3908.196000
    Metadata:
      title           : 00:59:41.244
    Chapter #0.12: start 3908.196000, end 4319.482000
    Metadata:
      title           : 01:05:08.196
    Chapter #0.13: start 4319.482000, end 4627.248000
    Metadata:
      title           : 01:11:59.482
    Chapter #0.14: start 4627.248000, end 4968.172000
    Metadata:
      title           : 01:17:07.248
    Chapter #0.15: start 4968.172000, end 5347.050000
    Metadata:
      title           : 01:22:48.172
    Chapter #0.16: start 5347.050000, end 5583.244000
    Metadata:
      title           : 01:29:07.050
    Chapter #0.17: start 5583.244000, end 5828.698000
    Metadata:
      title           : 01:33:03.244
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x536 [PAR 1:1 DAR 160:67]
, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0.1(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s (default)
    Metadata:
      title           : DTS
    Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000
    Metadata:
      title           : English SDH
[2013-06-11 14:14:38,298] INFO DaoHelper - Checking database schema.
[2013-06-11 14:14:39,318] INFO DaoHelper - Done checking database schema.
[2013-06-11 14:14:39,408] INFO VersionService - Resolved local Subsonic version to: 4.8
[2013-06-11 14:14:39,568] INFO PlayerDao - Deleted 1 player(s) that haven't been used after Fri Apr 12 14:14:39 EDT 2013
[2013-06-11 14:14:39,618] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Jun 12 03:00:00 EDT 2013
[2013-06-11 14:14:39,658] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Jun 11 14:19:39 EDT 2013
[2013-06-11 14:14:42,719] INFO NetworkService - Successfully forwarding port 4040.
[2013-06-11 14:14:46,119] INFO StreamController - Got range: Range[0,9223372036854775807]
[2013-06-11 14:14:46,119] INFO PlayQueueInputStream - admin listening to "Soul Searching Sun\05 My Mind Is Dangerous(1).mp3"
[2013-06-11 14:15:23,633] INFO PlayerDao - Created player 5.
[2013-06-11 14:15:23,723] INFO VersionService - Resolved latest Subsonic final version to: 4.8
[2013-06-11 14:15:23,723] INFO VersionService - Resolved latest Subsonic beta version to: 4.7.beta3
[2013-06-11 14:18:51,653] INFO StreamController - Got range: Range[0,9223372036854775807]
[2013-06-11 14:18:51,653] INFO PlayQueueInputStream - admin listening to "Dubstep Allstars Volume 6\09 Infinity Is Now.mp3"
[2013-06-11 14:18:51,663] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-i] [C:\Users\mineOS\Music\Peverelist\Dubstep Allstars Volume 6\09 Infinity Is Now.mp3] [-ab] [192k] [-v] [0] [-f] [mp3] [-]
[2013-06-11 14:19:39,673] INFO PodcastService - Starting scheduled Podcast refresh.
[2013-06-11 14:19:39,673] INFO PodcastService - Completed scheduled Podcast refresh.
cyris69
