Kubuntu 13.04 media folders not found
Postby bruhja » Thu Jun 20, 2013 6:41 pm
Every time I need to reboot my media server I get media folder not found in subsonic which forces me to manually re-input and rescan my media folders.
Am i missing some kind of policy or permissions?
I am running
-subsonic Premium 4.8 (build 3434) – April 17, 2013
-java version jetty-6.1.x, java 1.6.0_27, Linux
-Kubuntu 13.04
I have followed the installation instructions and all is working perfectly other than this one particular annoyance.
Please help.
bruhja
Re: Kubuntu 13.04 media folders not found
Postby Aethies » Thu Jun 20, 2013 7:13 pm
Can you be more specific? Are you having to input your media folders every time you reboot? Or is it not automounting your media folders?
Are your permissions on the media folders accessible by the same account that is running subsonic?
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby bruhja » Thu Jun 20, 2013 7:30 pm
The paths to the folders will still be there but i will get a message of "media folder not found" under settings media folders viewing subsonic in my browser. The paths will still be there but not linking, so then I have to delete the entries, open my file manager navigate to the folder I want to add then copy and past it back in, rinse repeat for all folders and rescan the media files.
Yes I can access the folders/files through my file manager without any issues.
But on a side note the drive containing the folders is an NTFS volume, as my system is a dualboot win7/linux system. This is a second drive not my actual windows volume.
bruhja
Postby bruhja » Sat Jun 22, 2013 4:21 am
*bump
bruhja
