File Error after playing each file using Substream on iPhone
Postby Greg27 » Mon Jul 22, 2013 11:27 am
Hello all,
I'm using Substream on an iPhone. Every time after playing any file I'm getting the following pop-up:
File Error
Unable to configure network read stream.
It doesn't make any difference if I'm connected via the local network or via 3G.
After selecting OK Substream remains connected to the file list and I can select any files to play. However, at
the end of each file the error returns.
Any idea how to fix this? I'm not sure if it's related to Subsonic or Substream, or something else...
G.
Greg27
Re: File Error after playing each file using Substream on iP
Postby Greg27 » Tue Jul 23, 2013 2:55 pm
Thoughts anyone? :roll:
Greg27
Postby daneren2005 » Tue Jul 23, 2013 5:34 pm
Start with contacting whoever wrote Substream...
Postby Greg27 » Thu Jul 25, 2013 8:16 am
I could have expected such a response, but thanks :) It kinda confirms that it's not likely a Subsonic issue.
Looking for support on Substream was a bit of a dead end... I've installed iSub now which works like a charm.
Greg27
