Downloading from remote site
Postby Es0ter1c » Thu Jul 31, 2008 2:59 pm
Does setting up a webpage/url allow me to download content from my library directly to another remote machine? Or is it only for streaming? I am kind of confused. Thanks!
Es0
Additionally, is there any way to use Subsonic to actually download the files to another PC via the internet and the url/site?
Es0ter1c
Re: Downloading from remote site
Postby M0NG0 » Fri Aug 01, 2008 4:43 am
Es0ter1c wrote:Does setting up a webpage/url allow me to download content from my library directly to another remote machine? Or is it only for streaming? I am kind of confused. Thanks!
Es0
When a user with 'download' rights logs into your installation of Subsonic, they should see a 'D' button next to the Play [>], and Add [+] buttons, which should initiate a download (zip file). To give a user download rights, log in as admin, then check the box under Settings -> Users -> 'User is allowed to download files'. Once the file has downloaded, the User will need to extract the file.
M0NG0
