OpenLDAP - STARTTLS??
Postby batmads » Mon Jul 29, 2013 1:36 pm
Hi Forum,
Did anyone actually make Subsonic work with OpenLDAP and TLS? I see very few discussions about this setup, and none of them has helped me.
MyLDAP authentication works fine With TLS for other tools like OwnCloud, Drupal and Apache. It also works for Subsonic without TLS, but when TLS is enabled on the LDAP server, I am getting:
subsonic.log:
INFO SubsonicLdapBindAuthenticator - Failed to authenticate user 'mads' in LDAP.
org.acegisecurity.ldap.LdapDataAccessException: Failed to obtain InitialDirContext due to unexpected exception; nested exception is javax.naming.AuthenticationNotSupportedException: [LDAP: error code 13 - confidentiality required]
LDAP.log:
: send_ldap_result: err=13 matched="" text="confidentiality required"
: conn=1005 op=0 RESULT tag=97 err=13 text=confidentiality required
: connection_read(14): input error=-2 id=1005, closing.
: connection_closing: readying conn=1005 sd=14 for close
Config:
FreeBSD 9.1
Subsonic Premium 4.8 (build 3434) – April 17, 2013 (WAR install on tomcat-6.0.37)
Openjdk-7.25.15
OpenLDAP-2.4.35
Any assistance is very apreciated - Even if it is an RTMF link. Thanks in advance
/Mads
batmads
Re: OpenLDAP - STARTTLS??
Postby batmads » Tue Sep 17, 2013 2:33 pm
I am taking the obvious silence from the forum as a sign, that noone has made it work with OpenLDAP, STARTTLS and Subsonic.. :shock:
Yes?
No?
/Mads
batmads
Postby sir2u » Mon Oct 14, 2013 9:55 pm
Did you install the SSL cert on the subsonic server? What kind of install did you use- Standalone or WAR?
sir2u
Users browsing this forum: Google [Bot] and 24 guests
