trouble installing with Ubuntu 12.12
Postby o_dawn_piano » Tue Aug 06, 2013 6:58 pm
Problem Description: Following the installation guide, i got this error in terminal:
Troubleshooting Steps: I found the package in my file manager and opened it in the Ubuntu Software Center.
This happened:
Playback Application and version: Android app
Subsonic Version: 4.8.deb
Server Version: n/a
Hardware Platform: Linux - Ubuntu 12.12
Java Memory Limit: IDK
Problem Filename: Subsonic-4.8.deb
Output from ffmpeg -i:
The program 'ffmpeg' is currently not installed.  You can install it by typing:
sudo apt-get install libav-tools
Last ten log file lines: n/a
o_dawn_piano
Re: trouble installing with Ubuntu 12.12
Postby cyrus » Tue Aug 06, 2013 8:27 pm
I think I can see two possible errors that you might want to correct:
1) line 8 indicates that you have issued the following instruction: sudo dpkg -i subsonic-x.x.deb
2) line 13 indicates that you have issued the following instruction: sudo dpkg -i subonic-4.8.deb
Both of these lines contain errors. Line 8 doesn't indicate the version (4.8.deb) but refers to x.x.deb; line 13 spells subsonic incorrectly (misses out "s")
Change directory to the directory you downloaded the installation package to and try reissuing the following instruction:
sudo dpkg -i subsonic-4.8.deb
Hopefully, that should work (or, at least it did on my Ubuntu system)
Good luck!
cyrus
Postby o_dawn_piano » Wed Aug 07, 2013 5:42 am
cyrus wrote:I think I can see two possible errors that you might want to correct:
ok thanks!
well, i guess it installed, but i can't find it.
o_dawn_piano
Postby cyrus » Wed Aug 07, 2013 7:59 pm
Ok -to see if it is installed type in terminal:
dpkg -s subsonic
That will tell you whether the install was successful or not.
If it was , go to your browser and type:
Http://localhost:4040
That should open the welcome page where you type in your username and password. If this is the first installation on your system, these are admin and admin
Hope that helps!
cyrus
Users browsing this forum: Google [Bot] and 13 guests
