Tomcat6 memory usage on Ubuntu
Postby spookybathtub » Mon Aug 12, 2013 2:44 am
Hello. I'm running subsonic 4.7 in Tomcat6 on Ubuntu 12.04. It's a low-power HTPC, with only 2GB of memory, and I'm trying to troubleshoot why my system is running out of memory sometimes. The 'java' process sometimes uses around 17% memory according to top. When I restart the tomcat6 service, it's immediately using about 13% memory. Subsonic is the only webapp I'm running. Any suggestions on how to reduce memory usage? I only have 1 regular user on subsonic, and about 10k songs.
spookybathtub
Re: Tomcat6 memory usage on Ubuntu
Postby Windependence » Wed Aug 21, 2013 7:27 pm
Unfortunately what you are experiencing is rather normal. The usage you are citing in your example is actually really good as the java process is generally quite a memory hog. This app, like most java apps, really likes more memory if you can give it. I'm running 6 GB in my setup and it runs much better than when I was running just 2 GB.
As an aside, you could try different JVMs and the memory footprint may vary slightly but really I would say you are doing good if the process is only consuming 17% of your available RAM on a system with 2GB.
-Tim
Windependence
