Saving Playlists
Saving Playlists
Postby bluetooth » Fri Aug 08, 2008 3:29 pm
I'm hoping this is because I just don't know how to do it.
I'm trying to build a playlist that can be saved and retrieved & played later. This is the kind of thing I used to do in Winamp all the time for parties. Then as the party is going on, it would either play untouched, or be added to.
Is it possible to save and retrieve playlists somehow?
bluetooth
Postby sindre_mehus » Sat Aug 09, 2008 10:42 am
Yes, that's possible. In the playlist frame, select "More actions", then "Load/Save playlist".
See also Settings > Users > User is allows to create and edit playlists.
Postby bluetooth » Sat Aug 09, 2008 11:47 am
I can see the random playlist option under More, but nothing on saving/loading playlists.
bluetooth
Postby bluetooth » Mon Aug 11, 2008 11:40 am
Now I see I can only manage playlists if the webplayer option is turned OFF.
bluetooth
Postby kapz » Tue Aug 19, 2008 5:18 pm
make sure the user you are logged in as has permission "User is allowed to create and delete playlists" checked.
kapz
