Webapp - Some songs stop playing /streaming during playback
Postby CableNinja » Fri Aug 16, 2013 7:16 am
Problem Description: Certain songs stop streaming / playing during playback on Webapp
Troubleshooting Steps: Verified song works elsewhere, verified song works on other subsonic platform (Android)
Playback Application and version: Webapp
Subsonic Version: 4.8 (build 3434) – April 17, 2013
Server Version: jetty-6.1.x, java 1.6.0_27, Linux (72.5 MB / 111.3 MB)
Hardware Platform: Linux, Debian Wheezy
Java Memory Limit: I couldnt locate any specific configuration, other than what I set in /etc/default/subsonic. SUBSONIC_ARGS="--port=8080 --max-memory=256 --default-music-folder=/storage"
Problem Filename:
Pet Thirteenth Step A Perfect Circle 2003 mp3 6.3 MB 4:33 192 Kbps - /storage/A\ Perfect\ Circle/Thirteenth\ Step/A\ Perfect\ Circle\ \-\ Pet.mp3
Output from ffmpeg -i:
# ffmpeg -i A\ Perfect\ Circle\ -\ Pet.mp3
ffmpeg version 0.8.6-6:0.8.6-1, Copyright (c) 2000-2013 the Libav developers
  built on Mar 24 2013 18:40:26 with gcc 4.7.2
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a future release. Please use avconv instead.
[mp3 @ 0x798b20] max_analyze_duration reached
Input #0, mp3, from 'A Perfect Circle - Pet.mp3':
  Metadata:
    title           : Pet
    publisher       : EMI
    genre           : Alt. Rock
    album           : Thirteenth Step
    album_artist    : A Perfect Circle
    track           : 10
    composer        :
    date            : 2003
  Duration: 00:04:33.55, start: 0.000000, bitrate: 192 kb/s
    Stream #0.0: Audio: mp3, 44100 Hz, stereo, s16, 192 kb/s
Last ten log file lines:
[2013-08-16 00:09:53,210] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TDRL            : 2005
[2013-08-16 00:09:53,210] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TCON            : Dance
[2013-08-16 00:09:53,210] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     DESCRIPTION     :
[2013-08-16 00:09:53,210] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     TSSE            : Lavf53.6.0
[2013-08-16 00:09:53,210] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: libmp3lame, 48000 Hz, stereo, s32, 128 kb/s
[2013-08-16 00:09:53,210] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2013-08-16 00:09:53,210] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2013-08-16 00:09:53,210] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[2013-08-16 00:09:53,211] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Warning, using s16 intermediate sample format for resampling
[2013-08-16 00:11:56,084] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [flac @ 0xa48a9c0] overread: 1401
[2013-08-16 00:11:56,085] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Error while decoding stream #0.0
[2013-08-16 00:11:56,089] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    2714kB time=00:02:53.68 bitrate= 128.0kbits/s
[2013-08-16 00:11:56,089] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) video:0kB audio:2714kB global headers:0kB muxing overhead 0.011551%
[2013-08-16 00:12:47,221] INFO PlayQueueInputStream - cableninja listening to "Yes Im Limited Vol VI/210_leaether_strip-going_nowhere_(club_version).mp3"
[2013-08-16 00:19:22,538] INFO PlayQueueInputStream - cableninja listening to "Frontfeuer/03. A Kind Of Deutsch.mp3"
[2013-08-16 00:25:34,309] INFO PlayQueueInputStream - cableninja listening to "Thirteenth Step/A Perfect Circle - Pet.mp3"
[2013-08-16 00:35:31,575] INFO PlayQueueInputStream - cableninja listening to "Harsh Generation/02 - Grendel - Harsh Generation.mp3"
[2013-08-16 00:35:31,578] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/storage/Grendel/Harsh Generation/02 - Grendel - Harsh Generation.mp3] [-ab] [96k] [-v] [0] [-f] [mp3] [-]
[2013-08-16 00:35:31,612] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[2013-08-16 00:35:31,613] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Aug  9 2011 14:18:27 with gcc 4.5.2
CableNinja
