Scan stops without apparent reason
Postby pderwael » Mon Aug 26, 2013 7:40 pm
Hi there
I'm in the process of relocating my mp3 collection from a win7+local & usb discs to a CentOS6.4+NAS
SS 4.8 (build 3434) - 17 avril 2013
Java: jetty-6.1.x, java 1.7.0_25, Linux (130,2 MB / 140,1 MB)
Running on CensOS 6.4 fully patched
The data is moved across, SS is installed, and running with 2MB RAM (--max-memory=2048)
The data is exported from the nas (CIFS read only) and mounted at /var/music
I have pointed SS at 29 directories under /var/music:
/var/music/0
/var/music/A
/var/music/B
/var/music/...
/var/music/Z
/var/music/~Ipod
/var/music/~Check
Started the media scan and everything seems ok until the scan progress (followed on /var/subsonic/subsonic.log) stops at
[2013-08-26 21:05:10,552] INFO MediaScannerService - Scanned media library with 142250 entries.
It should find +/- 400000 entries
"service subsonic stop" --> failed
"service subsonic status" --> subsonic dead but subsys locked
The web interface seems ok: I can play the music that has already been found, create playlists etc...
This is also true for music stored under ~Ipod & ~Check --> I don't think the "~" is the culprit
It seems that only the scan died...
Any clue gurus ??
pderwael
Re: Scan stops without apparent reason
Postby BKKKPewsey » Tue Aug 27, 2013 4:18 pm
With that directory structure it should be easy to find where the problem is.
Making the assumption that the A folder contains artists starting with A etc then look at your already scanned music and find where the scan failed.
eg if you have all artists up to M with only a few M's then the likelihood is that something in the M folder is causing SS to trip up.
So disable the M folder from the scan and rescan - if the scan now completes then case is proven.
However finding the problem file(s) within the suspect directory not quite so easy :|
pderwael wrote:SS is installed, and running with 2MB RAM
Of course if that is trúe you may need to buy some more memory
(Hmm! SS running on a Sinclair spectrum - unusual :) )
Postby pderwael » Tue Aug 27, 2013 4:38 pm
Thanks for the hint, I did not really suspect a corrupt file because the Windows version of SS is not crashing on the same directory structure and files
I have currently switched back to the Windows version of SS which is running on my laptop
Anyhow, I will try to scan every single directory one by one... I know what I will do this evening :(
Concerning the 2MB story, it is not running on a Sinclair, but on a ZX80... remember this one :roll:
Now seriously, I have set the max memory limit of both Win & Linux versions to 2Mb, and this is enough on my Win7
pderwael
Postby pderwael » Tue Aug 27, 2013 5:56 pm
I'm having second thoughts...
Instead of spending hours (if not days) trying every single directory (+/- 30,000 equivalent CDs, you get the picture), is there no possibility to activate a debug mode ??
Ideally, the scan should throw up an exception when a corrupt file is found...
Alternatively, every file scanned should be reported
Any thought on this ?
pderwael
