Subsonic Fails to play vbr
Postby Bromeister » Wed Aug 28, 2013 7:06 am
About half my library isn't playing since i upgraded to the 4.8 tomcat6 installation. In the now playing list the files always say "***kbs vbr" at the end (as opposed to files that just display the bitrate and play fine). Tried it on multiple computers with multiple browsers as well as DSub. I would like to fix this and really don't want to go back to jetty and lose my ssl. I am using Ubuntu 12.04 server.
Bromeister
Postby paulodell » Wed Aug 28, 2013 8:00 am
Bromeister wrote:About half my library isn't playing since i upgraded to the 4.8 tomcat6 installation. In the now playing list the files always say "***kbs vbr" at the end (as opposed to files that just display the bitrate and play fine). Tried it on multiple computers with multiple browsers as well as DSub. I would like to fix this and really don't want to go back to jetty and lose my ssl. I am using Ubuntu 12.04 server.
Give the transcoder in my signature a try, it converts mp3 to mp3 which stops the vbr
Paul
SubWiji http://tinyurl.com/7sxwbfv Install http://subwiji.paulodell.co.uk
Transcode Step1 "ffmpeg -f mp3 -i %s -ab %bk -v 0 -f mp3 -"
Tremor Games http://www.tremorgames.com/?ref=59174
paulodell
Re: Subsonic Fails to play vbr
Postby Bromeister » Wed Aug 28, 2013 8:17 am
Tried it but it caused all of my library to not be playable. I put the line in as step 1 and set both convert to and convert from as mp3.
The rest of my transcode lines are the default ones.
Bromeister
Users browsing this forum: No registered users and 69 guests
