Video player error
Video player error
Postby ufo56 » Wed Aug 28, 2013 3:22 pm
Hi
When i try to play video files from subsonic then i get this error
Link to screenshot https://www.dropbox.com/s/r6ytqsh1y1500 ... 181856.png
Error log from subsonic log file
[8/28/13 6:18:46 PM EEST]   INFO   PlayQueueInputStream   admin listening to "S04/4x01 Working for Caligula.avi"
[8/28/13 6:18:46 PM EEST]   DEBUG   TranscodeInputStream   Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/var/music/video/Kaks.ja.pool.meest.S01-07/S04/4x01 Working for Caligula.avi] [-async] [1] [-b] [1000k] [-s] [608x336] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-vcodec] [libx264] [-preset] [superfast] [-threads] [0] [-]
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) built on Aug 9 2011 14:18:27 with gcc 4.5.2
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavutil 51. 11. 1 / 51. 11. 1
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavcodec 53. 9. 1 / 53. 9. 1
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavformat 53. 6. 0 / 53. 6. 0
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavdevice 53. 2. 0 / 53. 2. 0
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libavfilter 2. 28. 1 / 2. 28. 1
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libswscale 2. 0. 0 / 2. 0. 0
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (2997003/125000)
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Input #0, avi, from '/var/music/video/Kaks.ja.pool.meest.S01-07/S04/4x01 Working for Caligula.avi':
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Metadata:
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) encoder : cant touch this
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Duration: 00:21:33.33, start: 0.000000, bitrate: 1128 kb/s
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0: Video: mpeg4 (Advanced Simple Profile), yuv420p, 608x336 [SAR 1:1 DAR 38:21], 23.98 tbr, 23.98 tbn, 23.98 tbc
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 128 kb/s
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [buffer @ 0x9ac5b60] w:608 h:336 pixfmt:yuv420p tb:1/1000000 sar:1/1 sws_param:
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [libx264 @ 0x9ac2d80] using SAR=1/1
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [libx264 @ 0x9ac2d80] using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [libx264 @ 0x9ac2d80] profile High, level 2.2
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [libx264 @ 0x9ac2d80] 264 - core 116 r2044 392e762 - H.264/MPEG-4 AVC codec - Copyleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=3 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc=abr mbtree=0 bitrate=1000 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Output #0, flv, to 'pipe:':
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) encoder : Lavf53.6.0
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0: Video: libx264, yuv420p, 608x336 [SAR 1:1 DAR 38:21], q=2-31, 1000 kb/s, 1k tbn, 23.98 tbc
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.1: Audio: libmp3lame, 44100 Hz, 2 channels, s16, 64 kb/s
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream mapping:
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.1 -> #0.1
[8/28/13 6:18:46 PM EEST]   DEBUG   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
Transcoding settings
flv/h264 video | avi mpg mpeg mp4 m4v mkv mov wmv ogv divx m2ts | flv | ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -vcodec libx264 -preset superfast -threads 0 -
mp4/h264 video | avi mpg mpeg mp4 m4v mkv mov wmv ogv divx m2ts| webm | ffmpeg -ss %o -t %d -i %s -async 1 -vf lutyuv=y=val*1.1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f webm -vcodec libvpx -preset superfast -acodec libvorbis -threads 0 -
JW player is updated to 6.5 ver , tutorial viewtopic.php?t=5977
ufo56
