Can't get Port Forwarding to work on New ASUS RT-N66u
Postby Patrikc325 » Sat Aug 31, 2013 2:59 pm
I have tried multiple settings but i can not get Subsonic to work.
The Asus RT-N66U port forwarding seems to be the problem.
Anyone have any idead?
Patrikc325
Re: Can't get Port Forwarding to work on New ASUS RT-N66u
Postby GJ51 » Sun Sep 01, 2013 2:03 am
Also make sure that the firewall is open on the host machine. Depending on the OS and the version of SS used, you sometimes have to open the port on the firewall of the server manually.
Postby Patrikc325 » Sun Sep 01, 2013 3:07 am
windows7 64bit The windows firewall has subsonic allowed. The settings are the same as for the squeezebox.
Patrikc325
Postby GJ51 » Sun Sep 01, 2013 3:26 am
So you are able to access Subsonic internally on your network, just not able to access from outside?
Postby Patrikc325 » Sun Sep 01, 2013 3:37 am
The Subsonic Music streamer sits green.
Ok it just worked. Not sure if i did it with the router or windows firewall.
Patrikc325
