Empty folders on Raspberry
Postby zycker » Mon Sep 09, 2013 9:52 pm
Hi there,
I'm moving my home server from a PC with Windows 7 to a Raspberry Pi.
Software side :
- Raspian Wheely
- Subsonic Version 4.8 (build 3434) – April 17, 2013
- Server jetty-6.1.x, java 1.8.0-ea, Linux (34.8 MB / 52.7 MB)
- 300MB of max allocated memory
Fresh install of Raspbian, first I've installed Java 1.8 followed by Subsonic. I've started testing my music folder scan by putting in just 3 albums (mp3 and flac), everything went fine (detection and playback) but then I've added a few more albums in the same folder but now :
My 6 albums appears on the left pannel but on the lower part I see this :
1 artists
1 albums
111 songs
757.1 MB
5 hours
And the 3 lasts albums I've added are empty when I choose them. I've manually started folder scan, data-base cleanup, service restart, reboot, uninstall subsonic + deleting all subsonic's folder, changing the music folder and the albums in there but I still have this problem :cry:
Here is the log, at this moment my task manager show 230MB used memory of 438MB :
98935 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 18435 ms
99139 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:8086
Subsonic running on: http://localhost:8086/
[GC (Allocation Failure) 14765K->10079K(18104K), 0.0473460 secs]
100411 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
100928 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
101941 [btpool0-1] INFO org.directwebremoting.log.startup - Starting: DwrServlet v3.0.0.116.rc1 on jetty-6.1.x / JDK 1.8.0-ea from Oracle Corporation at
102515 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: $
[GC (Allocation Failure) 15327K->11081K(18104K), 0.0896600 secs]
[GC (Allocation Failure) 16329K->11841K(18104K), 0.0487750 secs]
[GC (Allocation Failure) 17089K->12465K(18104K), 0.7258140 secs]
[GC (Allocation Failure) 17713K->13287K(18620K), 0.1685700 secs]
[Full GC (Allocation Failure) 13287K->11241K(18620K), 0.7049750 secs]
[GC (Allocation Failure) 18876K->12338K(27312K), 0.2259650 secs]
[GC (Allocation Failure) 20018K->12796K(27312K), 0.0684900 secs]
[GC (Allocation Failure) 20476K->13973K(27312K), 0.2133430 secs]
[GC (Allocation Failure) 21653K->15373K(27312K), 0.1358470 secs]
Is that a setting or hardware problem ? or a bug from Subsonic ?
zycker
Re: Empty folders on Raspberry
Postby alphawave7 » Mon Sep 09, 2013 10:40 pm
Looks like you need more memory...GC I believe stands for garbage collection, and it appears to be trying to grab more memory to work, but the heap is already full.
Postby zycker » Wed Sep 11, 2013 7:27 am
Ok so what can I do now that I have already modify /etc/default/subsonic to 512MB mo max memory which is the full capacity of the board that never seem top be fully used ?
zycker
Users browsing this forum: Google [Bot] and 28 guests
