Disabling Web Player
Postby DDJKSA » Mon Sep 16, 2013 7:01 am
Hi
Quick question - is there a way of disabling the web player for a guest user so that, in effect, guest users can only browse the online catalogue? I know how to deselect the option that allows the user to play files but this does not work in the Madsonic/MusicCabinet fork I am using (I have also posted this question in the Madsonic forum). I'm hoping that someone will be possibly able to show me how to cripple the player by deleting/modifying/renaming some of the files/code in the subsonic directory?
Thanks in advance
DDJ
DDJKSA
Re: Disabling Web Player
Postby BKKKPewsey » Mon Sep 16, 2013 10:57 pm
DDJKSA wrote:but this does not work in the Madsonic/MusicCabinet fork I am using
So which is it? those 2 forks are very different so you are using only one or the other or have dual services running. :?
This help thread is for Subsonic (vanilla) so post in the correct forum/sub forum if using a mod.
Unticking "allow user to play files" works fine for me in both SS 4.8 and Madsonic 5.0.3600.beta5
