Subsonic Vortexbox Server no longer accessible
Postby pc4ever1 » Mon Sep 16, 2013 7:15 pm
Subsonic Server no longer accessible
I have been using subsonic for at least a year without problems. Just over the weekend I was having problems getting access to my files.
The errors I get are different depending on if I use my phone, tablet or desktop : But basically its no access to the server.
I have putty'ed into my vortexbox to stop and start subsonic but keep getting errors.
I also deleted and reinstalled from the Web GUI. The problem installed OK but still had the same errors.
I then deleted and manually installed hoping it would fix itself.
Basically what I found it that the install hangs when getting to: http://dl.atrpms.net/f16-i386/atrpms...ata/repomd.xml
See errors Below:
Who controls this site "http://dl.atrpms.net" ?
I went to this site and the folder (f16-i386) that the install points to is no longer there.
Is there a new script to fix this?
Is anyone else having these issues?
Thanks in advance for your help!
Error code from the Vortexbox
[vortexbox.localdomain /]# yum localinstall subsonic-4.8.rpm
Loaded plugins: langpacks, presto, refresh-packagekit
http://dl.atrpms.net/f16-i386/atrpms...ta/repomd.xml: [Errno 14] HTTP Error 404 - Not Found : http://dl.atrpms.net/f16-i386/atrpms...ata/repomd.xml
Trying other mirror.
Error: Cannot retrieve repository metadata (repomd.xml) for repository: atrpms. Please verify its path and try again
pc4ever1
