(ConnectTimeoutException) What is this and how do I fix
Postby mrsucram » Fri Sep 20, 2013 1:22 pm
Greetings,
I am writing this question/assistance with the full knowledge that it may have already been posted and answered by someone else.
I am trying to get my subsonic up and running.
Status: Successfully forwarding port 4040.
Status: *******am.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
How do I correct/solve this connect Timeout.
Please don't bash my ignorance on this issue, as I don't have the full knowledge yet.
I thank you in advance.
Mr Sucram
mrsucram
Re: (ConnectTimeoutException) What is this and how do I fix
Postby GJ51 » Fri Sep 20, 2013 3:08 pm
Check port forwarding and firewall.
If you go to http://canyouseeme.org and enter your Subsonic port number it must respond as open or you won't be able to connect from outside.
Postby mrsucram » Fri Sep 20, 2013 4:04 pm
Thanks for your response and I got the following:
Error: I could not see your service on 75.181.92.74 on port (4040)
Reason: Connection timed out
mrsucram
Postby GJ51 » Fri Sep 20, 2013 4:26 pm
Then your router is probably not forwarding the port properly. The Tutorial section has good instructions that explain how to trouble shoot the issue. My post in the Windows/Anddoid section is relevant for any OS. Let me know if you have trouble after reviewing the tutorial.
