quality of sound / ios 7
Postby acemccracken » Fri Sep 20, 2013 10:48 pm
Since I upgraded to ios 7, the quality of the music has dropped significantly. It sounds like someone is mixing the tracks and leaving out half of them. If I listen to the music on my computer, it sounds fine. Anyone out there who knows or can help?
acemccracken
Re: quality of sound / ios 7
Postby daneren2005 » Fri Sep 20, 2013 11:15 pm
You will probably get better luck talking to whoever developed the app you are using. For example, if you are using iSub, they have their own dedicated forums.
