Multiple bugs...
Multiple bugs...
Postby bsny1122 » Tue Sep 24, 2013 10:09 pm
Android 4.2.2 (Galaxy S4 SPH-L720) Subsonic app
Server running Win7 Sp1
Both server and client are updated to the latest (premium) versions.
1. When starting to play a song that has not been cached, the song will play for a short time (5-30 seconds or so) and then stop to rebuffer even though the song is half-way or more downloaded (4/8 MB for example). It will do this repeatedly until the file is downloaded. Transcoding is disabled, but issue occurs on all file types.
2. When startng the subsonic service, 2 instances started. One has high memory usage (60-200 MB) and the other stays very low < 3MB. I can close the smaller instance with no apparent ill effects.
3. If connected to my car audio's bluetooth for media streaming and actively playing music, and then I turn the car off, after a few seconds the music will continue playing through the phone's speakers instead of pausing like it does when headphones are removed. If music is not playing, it will not start.
4.When music is playing and navigation is running, the music doesn't pause to be able to hear the navigation. It also will not pause when I activate voice recognition.
All of these issues were present when using my old Android phone as well (Motorola Photon).
bsny1122
