duplicate tracks in Subsonic, not in filesystem
Postby envoy510 » Sun Oct 06, 2013 8:37 pm
In the filesystem:
In the browser:
Latest Chrome (stable) latest Subsonic (Windows 7, 64-bit).
I rescanned the files. Same deal.
envoy510
Re: duplicate tracks in Subsonic, not in filesystem
Postby gurutech » Mon Oct 07, 2013 2:20 am
I've only seen this previously in playlists, but what you should do is disconnect your media folder from Subsonic, run a full scan (so it detects "0" media files), and then re-add your media folders and do another full scan.
gurutech
Postby envoy510 » Tue Oct 08, 2013 2:37 pm
I changed the media folder to something with no mp3s. Rescanned. Changed it back to the real media folder. Rescanned. Same problem.
envoy510
Postby envoy510 » Thu Oct 10, 2013 10:54 pm
No one has any ideas??
envoy510
Postby GJ51 » Thu Oct 10, 2013 11:34 pm
Probably need to clean up the db.
Postby envoy510 » Fri Oct 11, 2013 12:25 am
GJ51 wrote:Probably need to clean up the db.
I did that, too. Didn't help.
envoy510
Postby GJ51 » Fri Oct 11, 2013 3:41 am
It's been a while since I've used the regular Subsonic, but I think when I ran into this sort of thing before, I would uncheck all the folders as "enabled", then rescan empty and clean the db then re-enable the folders and scan fresh. That usually cleaned up most errors like this.
Postby envoy510 » Sun Oct 13, 2013 6:48 pm
GJ51 wrote:It's been a while since I've used the regular Subsonic, but I think when I ran into this sort of thing before, I would uncheck all the folders as "enabled", then rescan empty and clean the db then re-enable the folders and scan fresh. That usually cleaned up most errors like this.
I just did this and it did not fix the problem: uncheck the directory with my music, add a new, empty directory. Save. Scan media folders now. Clean up database. All my music was gone from the left sidebar, so I guess it's not in the database. Now, add the original directory back and scan. It took a very long time to scan all 9000+ songs. Go back to the same album with dups and they're there.
envoy510
