Ubuntu Server - Subsonic service stops every night?
Postby h311m4n » Wed Oct 16, 2013 9:01 am
Hi all,
Been really enjoying subsonic on windows already, but I thought I'd give it a shot on linux, especially since I'm a newbie at it so I thought it would be a cool way to learn something new.
So I've got Ubuntu server 12.04 running on a virtual machine, subsonic installed, windows shares mapped, everything works great. However, there's one thing I can't get my head around: every morning when I arrive at work, start my personal laptop to listen to my music, subsonic is unavailable and I have to manually start the subsonic service by remotely connecting to my home server running my VMs.
Does anyone else have this behavior? Is it normal that a service stops if unused? How do I get it fixed?
I've searched around on the interwebs thinking it might be because ubuntu server goes in some sort of sleep mode and kills unused services or processes but even after adding the acpi=off argument in grub, i'm still getting this behavior.
If someone could shed some light on this it would be really appreciated...:)
EDIT: I'm guessing there's a log that could tell me something about this problem, but where would it be?
Cheerios!
h311m4n
Re: Ubuntu Server - Subsonic service stops every night?
Postby Aethies » Wed Oct 16, 2013 1:29 pm
I don't know how much help I can be, but I can point you in several directions...
Logs - /var/log/subsonic
I use webmin to manage my server and in there under Other | System Status and Monitoring I have added a monitor that checks for the subsonic process and if it is not running, starts it for me. I also have one for a runaway mencoder process that has long since been fixed... But that isn't your problem.
Check your logs at /var/log/messages and see what is going on right around the time this happens. You should be able to see something in the subsonic logs around that time. Also, check your messages log around the same time and see what is shutting down services or maybe the server is rebooting? Not sure without poking around.
Anyway, I have been running subsonic under ubuntu server for a looong time now and I have had my issues but nothing too great that keeps it from running.
Hope this helps...
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
