Subsonic TV lite on Roku won't connect
Postby KTR » Thu Oct 17, 2013 12:27 am
so I've tried again to connect Subsonic TV lite to my Roku. Last time I gave up and the trail phase expired. The website instructions were either outdated or not readable, and I haven't found much in the forums. It works fine on the browser and in the demo mode. It finds my correct IP address easily (same for server as for PC) so I really don't know what else to try. I did not enable https for the port at the subsonic control panel. Any other suggestions, please?
KTR
Re: Subsonic TV lite on Roku won't connect
Postby Aethies » Thu Oct 17, 2013 4:07 pm
You should search for Subsonic TV and go to the home site. Then click on forums and then search the forums for SSL. There is a link in one of the posts that has the beta version that you need to get to use the ssl.
You can add that app for free.
Hope this helps
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby KTR » Thu Oct 17, 2013 4:58 pm
Thanks, but I'm not trying to use SSL. I have tried the beta version on Roku before and had the same problems connecting than with the Lite version.
KTR
Postby Aethies » Fri Oct 18, 2013 7:10 pm
Has anyone over at their forum site replied back to you? I wasn't sure if you had posted this same issue there...
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
Aethies
Postby KTR » Fri Oct 18, 2013 10:41 pm
No, I didn't post it there since you have to sign up for the google group. Does anybody know how to connect this?
KTR
