subsonic crash
subsonic crash
Postby henning » Thu Oct 17, 2013 7:46 am
I just noted that my subsonic installation did not work anymore and to safe some time I replaced the installation with a freshly downloaded one.
However it still does not work properly.
1. start with ./subsonic.sh
2. Open the subsonic webpage from another pc, I can log in and see all the contents.
3. Click on any of the buttons kills subsonic.
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007faf876c5641, pid=9830, tid=140391619061504
# JRE version: 6.0_27-b27
# Java VM: OpenJDK 64-Bit Server VM (20.0-b12 mixed mode linux-amd64 compressed oops)
# Derivative: IcedTea6 1.12.6
# Distribution: Debian GNU/Linux 6.0.4 (squeeze), package 6b27-1.12.6-1~deb6u1
# Problematic frame:
# C  [ld-linux-x86-64.so.2+0x13641]  _dl_make_stack_executable+0x20c1
# If you would like to submit a bug report, please include
# instructions how to reproduce the bug and visit:
#   http://icedtea.classpath.org/bugzilla
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  T H R E A D  ---------------
Current thread (0x0000000001f08000):  JavaThread "btpool0-1" [_thread_in_native, id=9864, stack(0x00007faf78856000,0x00007faf78957000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0x00000000000003d4
Registers:
RAX=0x00007faf876c5640, RBX=0x0000000000000000, RCX=0x00007faf86e77fe0, RDX=0x00007faf789566f8
RSP=0x00007faf78953550, RBP=0x00007faf86e77fe0, RSI=0x0000000000000000, RDI=0x0000000000000000
R8 =0x0000000000000000, R9 =0x00007faf86e780b0, R10=0x0000000000000000, R11=0x00007faf86e77ff0
R12=0x0000000000000000, R13=0x00007faf78953790, R14=0x00007faf78953788, R15=0x0000000001f08000
RIP=0x00007faf876c5641, EFLAGS=0x0000000000010246, CSGSFS=0x0000000000000033, ERR=0x0000000000000004
  TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00007faf78953550)
0x00007faf78953550:   0000000000000000 00007faf876bf906
0x00007faf78953560:   00007faf789566f8 0000000002ac8ff0
0x00007faf78953570:   0000000002ac8ff8 0000000002ac8fe8
0x00007faf78953580:   00007faf86e77fe0 0000000000000000
0x00007faf78953590:   00007faf78953790 0000000000000000
0x00007faf789535a0:   0000000001f08000 0000000002ac8fe0
0x00007faf789535b0:   4a14d045b91b48c7 0000000000000000
0x00007faf789535c0:   00007faf78953790 00007faf78953788
0x00007faf789535d0:   0000000001f08000 4a152ca12c1b48c7
0x00007faf789535e0:   4a14d35cb70d48c7 0000000000000005
0x00007faf789535f0:   00000000002093c8 0000000000000000
0x00007faf78953600:   00007faf78953788 0000000001f08000
0x00007faf78953610:   00007faf6b8bb000 00007faf876bf712
0x00007faf78953620:   00007faf00000005 0000000000000000
0x00007faf78953630:   00007faf78953790 00007faf86e775a0
0x00007faf78953640:   0000000001f08000 00007faf7c000020
0x00007faf78953650:   00007faf86e77fe0 0000000000000000
0x00007faf78953660:   00007faf78953790 00007faf78953788
0x00007faf78953670:   0000000001f08000 0000000000000000
0x00007faf78953680:   0000000002ac8fe0 00007faf86e782ec
0x00007faf78953690:   0000000000000000 00007faf789536d0
0x00007faf789536a0:   00007faf78953778 00007faf86e7800f
0x00007faf789536b0:   0000000000000006 00007faf6b8bdb28
0x00007faf789536c0:   00007faf816eddd0 0000000001f081d0
0x00007faf789536d0:   00007faf78953700 00007faf6b8bde1e
0x00007faf789536e0:   00000000ee8d6b88 0000000000000000
0x00007faf789536f0:   00000000ee8d6b88 00007faf78953798
0x00007faf78953700:   00007faf78953768 00007faf816f9d68
0x00007faf78953710:   00007faf78953790 00007faf816fb80c
0x00007faf78953720:   0000000001f08000 00007faf78953728
0x00007faf78953730:   00000000ee8d6b88 00007faf78953798
0x00007faf78953740:   00000000ee8dd6f0 0000000000000000
Instructions: (pc=0x00007faf876c5641)
0x00007faf876c5621:   85 e4 48 89 4d c0 0f 84 24 ff ff ff 4d 89 e7 c6
0x00007faf876c5631:   45 a8 01 e9 29 f9 ff ff 0f 1f 80 00 00 00 00 53
0x00007faf876c5641:   f6 87 d4 03 00 00 08 48 89 fb 75 32 44 8b 8f 10
0x00007faf876c5651:   03 00 00 45 85 c9 74 31 48 8d 3d e8 b2 20 00 ff
Register to memory mapping:
RAX=0x00007faf876c5640: <offset 0x13640> in /lib64/ld-linux-x86-64.so.2 at 0x00007faf876b2000
RBX=0x0000000000000000 is an unknown value
RCX=0x00007faf86e77fe0: <offset 0xfe0> in /lib/libdl.so.2 at 0x00007faf86e77000
RDX=0x00007faf789566f8 is pointing into the stack for thread: 0x0000000001f08000
RSP=0x00007faf78953550 is pointing into the stack for thread: 0x0000000001f08000
RBP=0x00007faf86e77fe0: <offset 0xfe0> in /lib/libdl.so.2 at 0x00007faf86e77000
RSI=0x0000000000000000 is an unknown value
RDI=0x0000000000000000 is an unknown value
R8 =0x0000000000000000 is an unknown value
R9 =0x00007faf86e780b0: <offset 0x10b0> in /lib/libdl.so.2 at 0x00007faf86e77000
R10=0x0000000000000000 is an unknown value
R11=0x00007faf86e77ff0: dlclose+0 in /lib/libdl.so.2 at 0x00007faf86e77000
R12=0x0000000000000000 is an unknown value
R13=0x00007faf78953790 is pointing into the stack for thread: 0x0000000001f08000
R14=0x00007faf78953788 is pointing into the stack for thread: 0x0000000001f08000
R15=0x0000000001f08000 is a thread
Stack: [0x00007faf78856000,0x00007faf78957000],  sp=0x00007faf78953550,  free space=1013k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  com.sun.imageio.plugins.jpeg.JPEGImageReader.initReaderIDs(Ljava/lang/Class;Ljava/lang/Class;Ljava/lang/Class;)V+0
j  com.sun.imageio.plugins.jpeg.JPEGImageReader.<clinit>()V+23
v  ~StubRoutines::call_stub
j  com.sun.imageio.plugins.jpeg.JPEGImageReaderSpi.createReaderInstance(Ljava/lang/Object;)Ljavax/imageio/ImageReader;+0
j  javax.imageio.spi.ImageReaderSpi.createReaderInstance()Ljavax/imageio/ImageReader;+2
j  javax.imageio.ImageIO$ImageReaderIterator.next()Ljavax/imageio/ImageReader;+16
j  javax.imageio.ImageIO$ImageReaderIterator.next()Ljava/lang/Object;+1
j  javax.imageio.ImageIO.read(Ljavax/imageio/stream/ImageInputStream;)Ljava/awt/image/BufferedImage;+31
j  javax.imageio.ImageIO.read(Ljava/io/InputStream;)Ljava/awt/image/BufferedImage;+20
j  net.sourceforge.subsonic.controller.CoverArtController.sendDefault(Ljava/lang/Integer;Ljavax/servlet/http/HttpServletResponse;)V+13
j  net.sourceforge.subsonic.controller.CoverArtController.handleRequest(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)Lorg/springframework/web/servlet/ModelAndView;+70
j  org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;Ljava/lang/Object;)Lorg/springframework/web/servlet/ModelAndView;+6
j  org.springframework.web.servlet.DispatcherServlet.doDispatch(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V+224
j  org.springframework.web.servlet.DispatcherServlet.doService(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V+219
j  org.springframework.web.servlet.FrameworkServlet.processRequest(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V+10
j  org.springframework.web.servlet.FrameworkServlet.doGet(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V+3
j  javax.servlet.http.HttpServlet.service(Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;)V+77
j  javax.servlet.http.HttpServlet.service(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+30
j  org.mortbay.jetty.servlet.ServletHolder.handle(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+176
j  org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+103
j  org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+65
j  org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(Lorg/acegisecurity/intercept/web/FilterInvocation;)V+87
j  org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+15
j  org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+185
j  org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+37
j  org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+144
j  org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+313
j  org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+143
j  org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+429
j  org.acegisecurity.ui.AbstractProcessingFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+141
j  org.acegisecurity.ui.logout.LogoutFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+164
j  org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+259
j  org.acegisecurity.util.FilterChainProxy.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+172
j  org.acegisecurity.util.FilterToBeanProxy.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+18
j  org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;)V+53
j  net.sourceforge.subsonic.filter.RequestEncodingFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+20
j  net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+17
j  net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(Ljavax/servlet/ServletRequest;Ljavax/servlet/ServletResponse;Ljavax/servlet/FilterChain;)V+10
j  org.mortbay.jetty.servlet.ServletHandler.handle(Ljava/lang/String;Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;I)V+389
j  org.mortbay.jetty.security.SecurityHandler.handle(Ljava/lang/String;Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;I)V+299
j  org.mortbay.jetty.servlet.SessionHandler.handle(Ljava/lang/String;Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;I)V+226
j  org.mortbay.jetty.handler.ContextHandler.handle(Ljava/lang/String;Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;I)V+700
j  org.mortbay.jetty.webapp.WebAppContext.handle(Ljava/lang/String;Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;I)V+25
j  org.mortbay.jetty.handler.HandlerWrapper.handle(Ljava/lang/String;Ljavax/servlet/http/HttpServletRequest;Ljavax/servlet/http/HttpServletResponse;I)V+23
j  org.mortbay.jetty.Server.handle(Lorg/mortbay/jetty/HttpConnection;)V+110
j  org.mortbay.jetty.HttpConnection.handleRequest()V+131
j  org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete()V+428
J  org.mortbay.jetty.HttpParser.parseNext()J
j  org.mortbay.jetty.HttpParser.parseAvailable()J+44
j  org.mortbay.jetty.HttpConnection.handle()V+122
j  org.mortbay.io.nio.SelectChannelEndPoint.run()V+4
j  org.mortbay.thread.BoundedThreadPool$PoolThread.run()V+45
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x00007faf7c2be800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=9873, stack(0x00007faf6b7ba000,0x00007faf6b8bb000)]
  0x00007faf75b5f000 JavaThread "pool-4-thread-1" [_thread_blocked, id=9872, stack(0x00007faf78351000,0x00007faf78452000)]
  0x0000000002606800 JavaThread "btpool0-7" [_thread_blocked, id=9871, stack(0x00007faf78e5c000,0x00007faf78f5d000)]
  0x00000000020cf800 JavaThread "btpool0-6" [_thread_blocked, id=9870, stack(0x00007faf78452000,0x00007faf78553000)]
  0x0000000002448800 JavaThread "btpool0-5" [_thread_blocked, id=9869, stack(0x00007faf78553000,0x00007faf78654000)]
  0x0000000002447800 JavaThread "btpool0-4" [_thread_blocked, id=9868, stack(0x00007faf78654000,0x00007faf78755000)]
  0x0000000003863800 JavaThread "btpool0-3" [_thread_blocked, id=9867, stack(0x00007faf78755000,0x00007faf78856000)]
=>0x0000000001f08000 JavaThread "btpool0-1" [_thread_in_native, id=9864, stack(0x00007faf78856000,0x00007faf78957000)]
  0x00007faf7c31b000 JavaThread "DestroyJavaVM" [_thread_blocked, id=9831, stack(0x00007faf877bc000,0x00007faf878bd000)]
  0x00007faf7c02b000 JavaThread "GC Daemon" daemon [_thread_blocked, id=9863, stack(0x00007faf78957000,0x00007faf78a58000)]
  0x00007faf7c0ed800 JavaThread "RMI Reaper" [_thread_blocked, id=9862, stack(0x00007faf78a58000,0x00007faf78b59000)]
  0x00007faf7c572800 JavaThread "RMI TCP Accept-0" daemon [_thread_in_native, id=9861, stack(0x00007faf78b59000,0x00007faf78c5a000)]
  0x00007faf7c3e1000 JavaThread "RMI TCP Accept-9412" daemon [_thread_in_native, id=9860, stack(0x00007faf6beff000,0x00007faf6c000000)]
  0x00007faf7c644000 JavaThread "pool-3-thread-1" [_thread_blocked, id=9859, stack(0x00007faf78c5a000,0x00007faf78d5b000)]
  0x00007faf7425d000 JavaThread "pool-2-thread-1" daemon [_thread_blocked, id=9858, stack(0x00007faf78d5b000,0x00007faf78e5c000)]
  0x00007faf7c4ad000 JavaThread "pool-1-thread-2" [_thread_blocked, id=9856, stack(0x00007faf7957b000,0x00007faf7967c000)]
  0x00007faf7c509000 JavaThread "pool-1-thread-1" [_thread_blocked, id=9855, stack(0x00007faf7967c000,0x00007faf7977d000)]
  0x00007faf74ef3800 JavaThread "Timer-1" daemon [_thread_blocked, id=9854, stack(0x00007faf7977d000,0x00007faf7987e000)]
  0x00007faf7c552000 JavaThread "net.sf.ehcache.CacheManager@2d35da43" daemon [_thread_blocked, id=9853, stack(0x00007faf7ad1c000,0x00007faf7ae1d000)]
  0x00007faf7c41c000 JavaThread "HSQLDB Timer @41584807" daemon [_thread_blocked, id=9850, stack(0x00007faf7ae1d000,0x00007faf7af1e000)]
  0x00007faf7c392000 JavaThread "Timer-0" [_thread_blocked, id=9849, stack(0x00007faf7b126000,0x00007faf7b227000)]
  0x00007faf7c16b000 JavaThread "btpool0-0 - Acceptor0 SelectChannelConnector@0.0.0.0:4040" [_thread_in_native, id=9848, stack(0x00007faf7b4b3000,0x00007faf7b5b4000)]
  0x00007faf7c087000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=9846, stack(0x00007faf7b826000,0x00007faf7b927000)]
  0x00007faf7c085000 JavaThread "C2 CompilerThread1" daemon [_thread_in_native, id=9845, stack(0x00007faf7b927000,0x00007faf7ba28000)]
  0x00007faf7c07f800 JavaThread "C2 CompilerThread0" daemon [_thread_in_native, id=9844, stack(0x00007faf7ba28000,0x00007faf7bb29000)]
  0x00007faf7c07e000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=9843, stack(0x00007faf7bb29000,0x00007faf7bc2a000)]
  0x00007faf7c05f000 JavaThread "Finalizer" daemon [_thread_blocked, id=9842, stack(0x00007faf7beff000,0x00007faf7c000000)]
  0x00007faf7c05d000 JavaThread "Reference Handler" daemon [_thread_blocked, id=9841, stack(0x00007faf800eb000,0x00007faf801ec000)]
Other Threads:
  0x00007faf7c058000 VMThread [stack: 0x00007faf801ec000,0x00007faf802ed000] [id=9840]
  0x00007faf7c091800 WatcherThread [stack: 0x00007faf7b725000,0x00007faf7b826000] [id=9847]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen      total 34176K, used 18695K [0x00000000fce00000, 0x0000000100000000, 0x0000000100000000)
  eden space 17152K, 60% used [0x00000000fce00000,0x00000000fd80f6e8,0x00000000fdec0000)
  from space 17024K, 49% used [0x00000000fef60000,0x00000000ff792690,0x0000000100000000)
  to   space 17024K, 0% used [0x00000000fdec0000,0x00000000fdec0000,0x00000000fef60000)
PSOldGen        total 102400K, used 33633K [0x00000000f6a00000, 0x00000000fce00000, 0x00000000fce00000)
  object space 102400K, 32% used [0x00000000f6a00000,0x00000000f8ad8438,0x00000000fce00000)
PSPermGen       total 37824K, used 37769K [0x00000000ec400000, 0x00000000ee8f0000, 0x00000000f6a00000)
  object space 37824K, 99% used [0x00000000ec400000,0x00000000ee8e27f0,0x00000000ee8f0000)
Code Cache  [0x00007faf816e9000, 0x00007faf81959000, 0x00007faf846e9000)
total_blobs=888 nmethods=494 adapters=348 free_code_cache=47973632 largest_free_block=8640
Dynamic libraries:
00400000-00409000 r-xp 00000000 09:01 34923055                           /usr/lib/jvm/java-6-openjdk/jre/bin/java
00608000-00609000 rw-p 00008000 09:01 34923055                           /usr/lib/jvm/java-6-openjdk/jre/bin/java
01efe000-03e00000 rw-p 00000000 00:00 0                                  [heap]
ec400000-ee8f0000 rw-p 00000000 00:00 0
ee8f0000-f6a00000 rw-p 00000000 00:00 0
f6a00000-100000000 rw-p 00000000 00:00 0
7faf6b7ba000-7faf6b7bd000 ---p 00000000 00:00 0
7faf6b7bd000-7faf6b8bb000 rw-p 00000000 00:00 0
7faf6b8bb000-7faf6b8c4000 r-xp 00000000 09:01 34923063                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libjpeg.so
7faf6b8c4000-7faf6bac4000 ---p 00009000 09:01 34923063                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libjpeg.so
7faf6bac4000-7faf6bac5000 rw-p 00009000 09:01 34923063                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libjpeg.so
7faf6bac5000-7faf6baf6000 r-xp 00000000 09:01 34923078                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/liblcms.so
7faf6baf6000-7faf6bcf5000 ---p 00031000 09:01 34923078                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/liblcms.so
7faf6bcf5000-7faf6bcf7000 rw-p 00030000 09:01 34923078                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/liblcms.so
7faf6bcf7000-7faf6bcf9000 rw-p 00000000 00:00 0
7faf6bcf9000-7faf6bcff000 r-xp 00000000 09:01 34923070                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/headless/libmawt.so
7faf6bcff000-7faf6befe000 ---p 00006000 09:01 34923070                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/headless/libmawt.so
7faf6befe000-7faf6beff000 rw-p 00005000 09:01 34923070                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/headless/libmawt.so
7faf6beff000-7faf6bf02000 ---p 00000000 00:00 0
7faf6bf02000-7faf6c000000 rw-p 00000000 00:00 0
7faf6c000000-7faf74000000 rw-s 00000000 09:01 99796397                   /var/subsonic/db/subsonic.data
7faf74000000-7faf76875000 rw-p 00000000 00:00 0
7faf76875000-7faf78000000 ---p 00000000 00:00 0
7faf78078000-7faf78122000 r-xp 00000000 09:01 34923084                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libawt.so
7faf78122000-7faf78321000 ---p 000aa000 09:01 34923084                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libawt.so
7faf78321000-7faf7832d000 rw-p 000a9000 09:01 34923084                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libawt.so
7faf7832d000-7faf78351000 rw-p 00000000 00:00 0
7faf78351000-7faf78354000 ---p 00000000 00:00 0
7faf78354000-7faf78452000 rw-p 00000000 00:00 0
7faf78452000-7faf78455000 ---p 00000000 00:00 0
7faf78455000-7faf78553000 rw-p 00000000 00:00 0
7faf78553000-7faf78556000 ---p 00000000 00:00 0
7faf78556000-7faf78654000 rw-p 00000000 00:00 0
7faf78654000-7faf78657000 ---p 00000000 00:00 0
7faf78657000-7faf78755000 rw-p 00000000 00:00 0
7faf78755000-7faf78758000 ---p 00000000 00:00 0
7faf78758000-7faf78856000 rw-p 00000000 00:00 0
7faf78856000-7faf78859000 ---p 00000000 00:00 0
7faf78859000-7faf78957000 rw-p 00000000 00:00 0
7faf78957000-7faf7895a000 ---p 00000000 00:00 0
7faf7895a000-7faf78a58000 rw-p 00000000 00:00 0
7faf78a58000-7faf78a5b000 ---p 00000000 00:00 0
7faf78a5b000-7faf78b59000 rw-p 00000000 00:00 0
7faf78b59000-7faf78b5c000 ---p 00000000 00:00 0
7faf78b5c000-7faf78c5a000 rw-p 00000000 00:00 0
7faf78c5a000-7faf78c5d000 ---p 00000000 00:00 0
7faf78c5d000-7faf78d5b000 rw-p 00000000 00:00 0
7faf78d5b000-7faf78d5e000 ---p 00000000 00:00 0
7faf78d5e000-7faf78e5c000 rw-p 00000000 00:00 0
7faf78e5c000-7faf78e5f000 ---p 00000000 00:00 0
7faf78e5f000-7faf78f5d000 rw-p 00000000 00:00 0
7faf78f5d000-7faf78f70000 r-xp 00000000 09:01 68887842                   /lib/libresolv-2.11.3.so
7faf78f70000-7faf7916f000 ---p 00013000 09:01 68887842                   /lib/libresolv-2.11.3.so
7faf7916f000-7faf79170000 r--p 00012000 09:01 68887842                   /lib/libresolv-2.11.3.so
7faf79170000-7faf79171000 rw-p 00013000 09:01 68887842                   /lib/libresolv-2.11.3.so
7faf79171000-7faf79173000 rw-p 00000000 00:00 0
7faf79173000-7faf79178000 r-xp 00000000 09:01 68887857                   /lib/libnss_dns-2.11.3.so
7faf79178000-7faf79377000 ---p 00005000 09:01 68887857                   /lib/libnss_dns-2.11.3.so
7faf79377000-7faf79378000 r--p 00004000 09:01 68887857                   /lib/libnss_dns-2.11.3.so
7faf79378000-7faf79379000 rw-p 00005000 09:01 68887857                   /lib/libnss_dns-2.11.3.so
7faf79379000-7faf7937b000 r-xp 00000000 09:01 68887831                   /lib/libnss_mdns4_minimal.so.2
7faf7937b000-7faf7957a000 ---p 00002000 09:01 68887831                   /lib/libnss_mdns4_minimal.so.2
7faf7957a000-7faf7957b000 rw-p 00001000 09:01 68887831                   /lib/libnss_mdns4_minimal.so.2
7faf7957b000-7faf7957e000 ---p 00000000 00:00 0
7faf7957e000-7faf7967c000 rw-p 00000000 00:00 0
7faf7967c000-7faf7967f000 ---p 00000000 00:00 0
7faf7967f000-7faf7977d000 rw-p 00000000 00:00 0
7faf7977d000-7faf79780000 ---p 00000000 00:00 0
7faf79780000-7faf7987e000 rw-p 00000000 00:00 0
7faf7987e000-7faf798d5000 r-xp 00000000 09:01 34922778                   /usr/lib/nss/libfreebl3.so
7faf798d5000-7faf79ad5000 ---p 00057000 09:01 34922778                   /usr/lib/nss/libfreebl3.so
7faf79ad5000-7faf79ad7000 rw-p 00057000 09:01 34922778                   /usr/lib/nss/libfreebl3.so
7faf79ad7000-7faf79adb000 rw-p 00000000 00:00 0
7faf79adb000-7faf79b6f000 r-xp 00000000 09:01 34819293                   /usr/lib/libsqlite3.so.0.8.6
7faf79b6f000-7faf79d6e000 ---p 00094000 09:01 34819293                   /usr/lib/libsqlite3.so.0.8.6
7faf79d6e000-7faf79d72000 rw-p 00093000 09:01 34819293                   /usr/lib/libsqlite3.so.0.8.6
7faf79d72000-7faf79da6000 r-xp 00000000 09:01 34922776                   /usr/lib/nss/libsoftokn3.so
7faf79da6000-7faf79fa6000 ---p 00034000 09:01 34922776                   /usr/lib/nss/libsoftokn3.so
7faf79fa6000-7faf79fa8000 rw-p 00034000 09:01 34922776                   /usr/lib/nss/libsoftokn3.so
7faf79fa8000-7faf79fe1000 r-xp 00000000 09:01 34822005                   /usr/lib/libnspr4.so.0d
7faf79fe1000-7faf7a1e1000 ---p 00039000 09:01 34822005                   /usr/lib/libnspr4.so.0d
7faf7a1e1000-7faf7a1e3000 rw-p 00039000 09:01 34822005                   /usr/lib/libnspr4.so.0d
7faf7a1e3000-7faf7a1e6000 rw-p 00000000 00:00 0
7faf7a1e6000-7faf7a1e9000 r-xp 00000000 09:01 34822007                   /usr/lib/libplds4.so.0d
7faf7a1e9000-7faf7a3e8000 ---p 00003000 09:01 34822007                   /usr/lib/libplds4.so.0d
7faf7a3e8000-7faf7a3e9000 rw-p 00002000 09:01 34822007                   /usr/lib/libplds4.so.0d
7faf7a3e9000-7faf7a3ed000 r-xp 00000000 09:01 34822006                   /usr/lib/libplc4.so.0d
7faf7a3ed000-7faf7a5ec000 ---p 00004000 09:01 34822006                   /usr/lib/libplc4.so.0d
7faf7a5ec000-7faf7a5ed000 rw-p 00003000 09:01 34822006                   /usr/lib/libplc4.so.0d
7faf7a5ed000-7faf7a604000 r-xp 00000000 09:01 34820698                   /usr/lib/libnssutil3.so.1d
7faf7a604000-7faf7a803000 ---p 00017000 09:01 34820698                   /usr/lib/libnssutil3.so.1d
7faf7a803000-7faf7a809000 rw-p 00016000 09:01 34820698                   /usr/lib/libnssutil3.so.1d
7faf7a809000-7faf7a905000 r-xp 00000000 09:01 34820292                   /usr/lib/libnss3.so.1d
7faf7a905000-7faf7ab04000 ---p 000fc000 09:01 34820292                   /usr/lib/libnss3.so.1d
7faf7ab04000-7faf7ab0b000 rw-p 000fb000 09:01 34820292                   /usr/lib/libnss3.so.1d
7faf7ab0b000-7faf7ab0c000 rw-p 00000000 00:00 0
7faf7ab0c000-7faf7ab1c000 r-xp 00000000 09:01 34923067                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libj2pkcs11.so
7faf7ab1c000-7faf7ad1b000 ---p 00010000 09:01 34923067                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libj2pkcs11.so
7faf7ad1b000-7faf7ad1c000 rw-p 0000f000 09:01 34923067                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libj2pkcs11.so
7faf7ad1c000-7faf7ad1f000 ---p 00000000 00:00 0
7faf7ad1f000-7faf7ae1d000 rw-p 00000000 00:00 0
7faf7ae1d000-7faf7ae20000 ---p 00000000 00:00 0
7faf7ae20000-7faf7af1e000 rw-p 00000000 00:00 0
7faf7af1e000-7faf7af26000 r-xp 00000000 09:01 34923069                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libnio.so
7faf7af26000-7faf7b125000 ---p 00008000 09:01 34923069                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libnio.so
7faf7b125000-7faf7b126000 rw-p 00007000 09:01 34923069                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libnio.so
7faf7b126000-7faf7b129000 ---p 00000000 00:00 0
7faf7b129000-7faf7b227000 rw-p 00000000 00:00 0
7faf7b227000-7faf7b23c000 r-xp 00000000 09:01 34923080                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libnet.so
7faf7b23c000-7faf7b43b000 ---p 00015000 09:01 34923080                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libnet.so
7faf7b43b000-7faf7b43c000 rw-p 00014000 09:01 34923080                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libnet.so
7faf7b43c000-7faf7b43f000 r--s 0007f000 09:01 34923142                   /usr/lib/jvm/java-6-openjdk/jre/lib/jsse.jar
7faf7b43f000-7faf7b443000 r--s 0002f000 09:01 103441996                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/commons-lang-2.1.jar
7faf7b443000-7faf7b44c000 r--s 000c6000 09:01 103442022                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/yuicompressor-2.3.6.jar
7faf7b44c000-7faf7b44e000 r--s 00005000 09:01 103442014                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/slf4j-api-1.6.1.jar
7faf7b44e000-7faf7b454000 r--s 0002e000 09:01 103442012                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/radeox-1.0-b2.jar
7faf7b454000-7faf7b457000 r--s 00023000 09:01 103442005                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/jdom-1.0.jar
7faf7b457000-7faf7b45f000 r--s 00096000 09:01 103442000                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/hsqldb-1.8.0.7.jar
7faf7b45f000-7faf7b468000 r--s 0005a000 09:01 103442017                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/spring-webmvc-2.5.6.jar
7faf7b468000-7faf7b470000 r--s 00040000 09:01 103442001                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/httpclient-4.0.1.jar
7faf7b470000-7faf7b47d000 r--s 0007c000 09:01 103441992                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/commons-collections-3.1.jar
7faf7b47d000-7faf7b48f000 r--s 000eb000 09:01 103442009                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/lucene-core-3.0.3.jar
7faf7b48f000-7faf7b49e000 r--s 000e6000 09:01 103441987                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/ant-zip-1.6.2.jar
7faf7b49e000-7faf7b4aa000 r--s 000b4000 09:01 103442003                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/jaudiotagger-2.0.2.jar
7faf7b4aa000-7faf7b4b3000 r--s 00058000 09:01 103442018                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/standard-1.1.2.jar
7faf7b4b3000-7faf7b4b6000 ---p 00000000 00:00 0
7faf7b4b6000-7faf7b5b4000 rw-p 00000000 00:00 0
7faf7b5bd000-7faf7b5c4000 r--s 000fc000 09:01 34923136                   /usr/lib/jvm/java-6-openjdk/jre/lib/resources.jar
7faf7b5c4000-7faf7b5c6000 r--s 00000000 09:01 103441110                  /var/subsonic/jetty/3434/webapp/icons/sonic_blue/forward.png
7faf7b5c6000-7faf7b5c7000 r--s 00000000 09:01 103441348                  /var/subsonic/jetty/3434/webapp/script/fancyzoom/images/zoom-shadow7.png
7faf7b5c7000-7faf7b5c8000 r--s 00000000 09:01 103441346                  /var/subsonic/jetty/3434/webapp/script/fancyzoom/images/zoom-shadow5.png
7faf7b5c8000-7faf7b5c9000 r--s 00000000 09:01 103441345                  /var/subsonic/jetty/3434/webapp/script/fancyzoom/images/zoom-shadow4.png
7faf7b5c9000-7faf7b5ca000 r--s 00000000 09:01 103441343                  /var/subsonic/jetty/3434/webapp/script/fancyzoom/images/zoom-shadow2.png
7faf7b5ca000-7faf7b5ce000 r--s 00039000 09:01 34923122                   /usr/lib/jvm/java-6-openjdk/jre/lib/ext/sunpkcs11.jar
7faf7b5ce000-7faf7b5d0000 r--s 00013000 09:01 34923134                   /usr/lib/jvm/java-6-openjdk/jre/lib/jce.jar
7faf7b5d0000-7faf7b5d3000 r--s 00031000 09:01 34923120                   /usr/lib/jvm/java-6-openjdk/jre/lib/ext/sunjce_provider.jar
7faf7b5d3000-7faf7b67b000 r--s 009a5000 09:01 99786767                   /var/www/vhosts/brauwers.com/httpdocs/subsonic/subsonic-booter-jar-with-dependencies.jar
7faf7b67b000-7faf7b67d000 r--s 0000f000 09:01 34923126                   /usr/lib/jvm/java-6-openjdk/jre/lib/ext/pulse-java.jar
7faf7b67d000-7faf7b725000 r--s 009a5000 09:01 99786767                   /var/www/vhosts/brauwers.com/httpdocs/subsonic/subsonic-booter-jar-with-dependencies.jar
7faf7b725000-7faf7b726000 ---p 00000000 00:00 0
7faf7b726000-7faf7b826000 rw-p 00000000 00:00 0
7faf7b826000-7faf7b829000 ---p 00000000 00:00 0
7faf7b829000-7faf7b927000 rw-p 00000000 00:00 0
7faf7b927000-7faf7b92a000 ---p 00000000 00:00 0
7faf7b92a000-7faf7ba28000 rw-p 00000000 00:00 0
7faf7ba28000-7faf7ba2b000 ---p 00000000 00:00 0
7faf7ba2b000-7faf7bb29000 rw-p 00000000 00:00 0
7faf7bb29000-7faf7bb2c000 ---p 00000000 00:00 0
7faf7bb2c000-7faf7bc2a000 rw-p 00000000 00:00 0
7faf7bc2a000-7faf7beff000 r--p 00000000 09:01 34840891                   /usr/lib/locale/locale-archive
7faf7beff000-7faf7bf02000 ---p 00000000 00:00 0
7faf7bf02000-7faf7c000000 rw-p 00000000 00:00 0
7faf7c000000-7faf7d3f1000 rw-p 00000000 00:00 0
7faf7d3f1000-7faf80000000 ---p 00000000 00:00 0
7faf80000000-7faf80001000 r--s 00000000 09:01 103441339                  /var/subsonic/jetty/3434/webapp/script/fancyzoom/images/zoom-caption-fill.png
7faf80001000-7faf80007000 r--s 00046000 09:01 103442004                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/jcommon-1.0.14.jar
7faf80007000-7faf80008000 r--s 00006000 09:01 103441988                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/asm-1.5.3.jar
7faf80008000-7faf8000a000 r--s 00006000 09:01 103441991                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/commons-codec-1.2.jar
7faf8000a000-7faf80024000 r--s 0010e000 09:01 103441999                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/ehcache-core-2.5.0.jar
7faf80024000-7faf80026000 r--s 0000c000 09:01 103442020                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/weupnp-2009-10-16.jar
7faf80026000-7faf8002b000 r--s 00016000 09:01 103442021                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/xml-apis-1.0.b2.jar
7faf8002b000-7faf8003b000 r--s 0013d000 09:01 103442006                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/jfreechart-1.0.11.jar
7faf8003b000-7faf8003d000 r--s 0000a000 09:01 103442019                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/string-1.1.0.jar
7faf8003d000-7faf80050000 r--s 00103000 09:01 103441998                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/dwr-3.0.rc1.jar
7faf80050000-7faf80052000 r--s 00012000 09:01 103441990                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/commons-beanutils-1.4.jar
7faf80052000-7faf80054000 r--s 00004000 09:01 103442007                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/jstl-1.1.2.jar
7faf80054000-7faf8005a000 r--s 0003f000 09:01 103441989                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/cglib-2.1_3.jar
7faf8005a000-7faf8005d000 r--s 00025000 09:01 103442013                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/sbbi-upnplib-1.0.4.jar
7faf8005d000-7faf80066000 r--s 0006d000 09:01 103442008                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/log4j-1.2.16.jar
7faf80066000-7faf8006b000 r--s 00026000 09:01 103442002                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/httpcore-4.0.1.jar
7faf8006b000-7faf8006e000 r--s 00012000 09:01 103441994                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/commons-io-1.3.1.jar
7faf8006e000-7faf800ab000 r--s 00294000 09:01 103442016                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/spring-2.5.6.jar
7faf800ab000-7faf800ac000 r--s 00002000 09:01 103442015                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/slf4j-log4j12-1.6.1.jar
7faf800ac000-7faf800ae000 r--s 0000e000 09:01 103442011                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/oro-2.0.8.jar
7faf800ae000-7faf800af000 r--s 00006000 09:01 103442010                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/natpmp-0.1.jar
7faf800af000-7faf800b4000 r--s 0003d000 09:01 103441995                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/commons-jxpath-1.1.jar
7faf800b4000-7faf800bf000 r--s 00095000 09:01 103441986                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/ant-optional-1.5.1.jar
7faf800bf000-7faf800cc000 r--s 00079000 09:01 103441985                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/acegi-security-1.0.5.jar
7faf800cc000-7faf800eb000 r--s 01393000 09:01 99786770                   /var/www/vhosts/brauwers.com/httpdocs/subsonic/subsonic.war
7faf800eb000-7faf800ee000 ---p 00000000 00:00 0
7faf800ee000-7faf801ec000 rw-p 00000000 00:00 0
7faf801ec000-7faf801ed000 ---p 00000000 00:00 0
7faf801ed000-7faf80c29000 rw-p 00000000 00:00 0
7faf80c29000-7faf80dbd000 r--s 03807000 09:01 34923058                   /usr/lib/jvm/java-6-openjdk/jre/lib/rt.jar
7faf80dbd000-7faf80dbe000 ---p 00000000 00:00 0
7faf80dbe000-7faf80ebe000 rw-p 00000000 00:00 0
7faf80ebe000-7faf80ebf000 ---p 00000000 00:00 0
7faf80ebf000-7faf80fbf000 rw-p 00000000 00:00 0
7faf80fbf000-7faf80fc0000 ---p 00000000 00:00 0
7faf80fc0000-7faf810c0000 rw-p 00000000 00:00 0
7faf810c0000-7faf810c1000 ---p 00000000 00:00 0
7faf810c1000-7faf811c1000 rw-p 00000000 00:00 0
7faf811c1000-7faf811c2000 ---p 00000000 00:00 0
7faf811c2000-7faf812c2000 rw-p 00000000 00:00 0
7faf812c2000-7faf812c3000 ---p 00000000 00:00 0
7faf812c3000-7faf813c3000 rw-p 00000000 00:00 0
7faf813c3000-7faf813c4000 ---p 00000000 00:00 0
7faf813c4000-7faf814c4000 rw-p 00000000 00:00 0
7faf814c4000-7faf814c5000 ---p 00000000 00:00 0
7faf814c5000-7faf815d8000 rw-p 00000000 00:00 0
7faf815d8000-7faf81618000 rw-p 00000000 00:00 0
7faf81618000-7faf8165d000 rw-p 00000000 00:00 0
7faf8165d000-7faf8169d000 rw-p 00000000 00:00 0
7faf8169d000-7faf816e9000 rw-p 00000000 00:00 0
7faf816e9000-7faf81959000 rwxp 00000000 00:00 0
7faf81959000-7faf846e9000 rw-p 00000000 00:00 0
7faf846e9000-7faf846f0000 r-xp 00000000 09:01 34923076                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libzip.so
7faf846f0000-7faf848ef000 ---p 00007000 09:01 34923076                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libzip.so
7faf848ef000-7faf848f0000 rw-p 00006000 09:01 34923076                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libzip.so
7faf848f0000-7faf848fc000 r-xp 00000000 09:01 68887821                   /lib/libnss_files-2.11.3.so
7faf848fc000-7faf84afb000 ---p 0000c000 09:01 68887821                   /lib/libnss_files-2.11.3.so
7faf84afb000-7faf84afc000 r--p 0000b000 09:01 68887821                   /lib/libnss_files-2.11.3.so
7faf84afc000-7faf84afd000 rw-p 0000c000 09:01 68887821                   /lib/libnss_files-2.11.3.so
7faf84afd000-7faf84b07000 r-xp 00000000 09:01 68887863                   /lib/libnss_nis-2.11.3.so
7faf84b07000-7faf84d06000 ---p 0000a000 09:01 68887863                   /lib/libnss_nis-2.11.3.so
7faf84d06000-7faf84d07000 r--p 00009000 09:01 68887863                   /lib/libnss_nis-2.11.3.so
7faf84d07000-7faf84d08000 rw-p 0000a000 09:01 68887863                   /lib/libnss_nis-2.11.3.so
7faf84d08000-7faf84d0f000 r-xp 00000000 09:01 68887848                   /lib/libnss_compat-2.11.3.so
7faf84d0f000-7faf84f0e000 ---p 00007000 09:01 68887848                   /lib/libnss_compat-2.11.3.so
7faf84f0e000-7faf84f0f000 r--p 00006000 09:01 68887848                   /lib/libnss_compat-2.11.3.so
7faf84f0f000-7faf84f10000 rw-p 00007000 09:01 68887848                   /lib/libnss_compat-2.11.3.so
7faf84f10000-7faf84f25000 r-xp 00000000 09:01 68887853                   /lib/libnsl-2.11.3.so
7faf84f25000-7faf85124000 ---p 00015000 09:01 68887853                   /lib/libnsl-2.11.3.so
7faf85124000-7faf85125000 r--p 00014000 09:01 68887853                   /lib/libnsl-2.11.3.so
7faf85125000-7faf85126000 rw-p 00015000 09:01 68887853                   /lib/libnsl-2.11.3.so
7faf85126000-7faf85128000 rw-p 00000000 00:00 0
7faf85128000-7faf85154000 r-xp 00000000 09:01 34923081                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libjava.so
7faf85154000-7faf85353000 ---p 0002c000 09:01 34923081                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libjava.so
7faf85353000-7faf85357000 rw-p 0002b000 09:01 34923081                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libjava.so
7faf85357000-7faf85365000 r-xp 00000000 09:01 34923082                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libverify.so
7faf85365000-7faf85565000 ---p 0000e000 09:01 34923082                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libverify.so
7faf85565000-7faf85567000 rw-p 0000e000 09:01 34923082                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libverify.so
7faf85567000-7faf8556e000 r-xp 00000000 09:01 68887846                   /lib/librt-2.11.3.so
7faf8556e000-7faf8576d000 ---p 00007000 09:01 68887846                   /lib/librt-2.11.3.so
7faf8576d000-7faf8576e000 r--p 00006000 09:01 68887846                   /lib/librt-2.11.3.so
7faf8576e000-7faf8576f000 rw-p 00007000 09:01 68887846                   /lib/librt-2.11.3.so
7faf8576f000-7faf85785000 r-xp 00000000 09:01 68886569                   /lib/libgcc_s.so.1
7faf85785000-7faf85984000 ---p 00016000 09:01 68886569                   /lib/libgcc_s.so.1
7faf85984000-7faf85985000 rw-p 00015000 09:01 68886569                   /lib/libgcc_s.so.1
7faf85985000-7faf85a05000 r-xp 00000000 09:01 68887862                   /lib/libm-2.11.3.so
7faf85a05000-7faf85c05000 ---p 00080000 09:01 68887862                   /lib/libm-2.11.3.so
7faf85c05000-7faf85c06000 r--p 00080000 09:01 68887862                   /lib/libm-2.11.3.so
7faf85c06000-7faf85c07000 rw-p 00081000 09:01 68887862                   /lib/libm-2.11.3.so
7faf85c07000-7faf85cfd000 r-xp 00000000 09:01 34816953                   /usr/lib/libstdc++.so.6.0.13
7faf85cfd000-7faf85efd000 ---p 000f6000 09:01 34816953                   /usr/lib/libstdc++.so.6.0.13
7faf85efd000-7faf85f04000 r--p 000f6000 09:01 34816953                   /usr/lib/libstdc++.so.6.0.13
7faf85f04000-7faf85f06000 rw-p 000fd000 09:01 34816953                   /usr/lib/libstdc++.so.6.0.13
7faf85f06000-7faf85f1b000 rw-p 00000000 00:00 0
7faf85f1b000-7faf86852000 r-xp 00000000 09:01 34923072                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/server/libjvm.so
7faf86852000-7faf86a52000 ---p 00937000 09:01 34923072                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/server/libjvm.so
7faf86a52000-7faf86aed000 rw-p 00937000 09:01 34923072                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/server/libjvm.so
7faf86aed000-7faf86b15000 rw-p 00000000 00:00 0
7faf86b15000-7faf86c6e000 r-xp 00000000 09:01 68887849                   /lib/libc-2.11.3.so
7faf86c6e000-7faf86e6d000 ---p 00159000 09:01 68887849                   /lib/libc-2.11.3.so
7faf86e6d000-7faf86e71000 r--p 00158000 09:01 68887849                   /lib/libc-2.11.3.so
7faf86e71000-7faf86e72000 rw-p 0015c000 09:01 68887849                   /lib/libc-2.11.3.so
7faf86e72000-7faf86e77000 rw-p 00000000 00:00 0
7faf86e77000-7faf86e79000 r-xp 00000000 09:01 68887861                   /lib/libdl-2.11.3.so
7faf86e79000-7faf87079000 ---p 00002000 09:01 68887861                   /lib/libdl-2.11.3.so
7faf87079000-7faf8707a000 r--p 00002000 09:01 68887861                   /lib/libdl-2.11.3.so
7faf8707a000-7faf8707b000 rw-p 00003000 09:01 68887861                   /lib/libdl-2.11.3.so
7faf8707b000-7faf8707f000 r-xp 00000000 09:01 34923074                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/jli/libjli.so
7faf8707f000-7faf8727e000 ---p 00004000 09:01 34923074                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/jli/libjli.so
7faf8727e000-7faf8727f000 rw-p 00003000 09:01 34923074                   /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/jli/libjli.so
7faf8727f000-7faf87296000 r-xp 00000000 09:01 68887844                   /lib/libpthread-2.11.3.so
7faf87296000-7faf87495000 ---p 00017000 09:01 68887844                   /lib/libpthread-2.11.3.so
7faf87495000-7faf87496000 r--p 00016000 09:01 68887844                   /lib/libpthread-2.11.3.so
7faf87496000-7faf87497000 rw-p 00017000 09:01 68887844                   /lib/libpthread-2.11.3.so
7faf87497000-7faf8749b000 rw-p 00000000 00:00 0
7faf8749b000-7faf874b2000 r-xp 00000000 09:01 34818017                   /usr/lib/libz.so.1.2.3.4
7faf874b2000-7faf876b1000 ---p 00017000 09:01 34818017                   /usr/lib/libz.so.1.2.3.4
7faf876b1000-7faf876b2000 rw-p 00016000 09:01 34818017                   /usr/lib/libz.so.1.2.3.4
7faf876b2000-7faf876d0000 r-xp 00000000 09:01 68887845                   /lib/ld-2.11.3.so
7faf876d0000-7faf876d2000 r--s 0000d000 09:01 103441997                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/commons-logging-1.1.1.jar
7faf876d2000-7faf876d4000 r--s 0000b000 09:01 103441993                  /var/subsonic/jetty/3434/webapp/WEB-INF/lib/commons-fileupload-1.2.jar
7faf876d4000-7faf87706000 rw-p 00000000 00:00 0
7faf87706000-7faf877bc000 rw-p 00000000 00:00 0
7faf877bc000-7faf877bf000 ---p 00000000 00:00 0
7faf877bf000-7faf878c2000 rw-p 00000000 00:00 0
7faf878c2000-7faf878c3000 r--s 00000000 09:01 103441218                  /var/subsonic/jetty/3434/webapp/index.html
7faf878c3000-7faf878cb000 rw-s 00000000 09:01 6324232                    /tmp/hsperfdata_root/9830
7faf878cb000-7faf878cc000 rw-p 00000000 00:00 0
7faf878cc000-7faf878cd000 r--p 00000000 00:00 0
7faf878cd000-7faf878cf000 rw-p 00000000 00:00 0
7faf878cf000-7faf878d0000 r--p 0001d000 09:01 68887845                   /lib/ld-2.11.3.so
7faf878d0000-7faf878d1000 rw-p 0001e000 09:01 68887845                   /lib/ld-2.11.3.so
7faf878d1000-7faf878d2000 rw-p 00000000 00:00 0
7fff2fce1000-7fff2fd16000 rw-p 00000000 00:00 0                          [stack]
7fff2fd7c000-7fff2fd7d000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
VM Arguments:
jvm_args: -Xmx150m -Dsubsonic.home=/var/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=4040 -Dsubsonic.httpsPort=0 -Dsubsonic.contextPath=/ -Dsubsonic.defaultMusicFolder=/var/music -Dsubsonic.defaultPodcastFolder=/var/music/Podcast -Dsubsonic.defaultPlaylistFolder=/var/playlists -Djava.awt.headless=true -verbose:gc
java_command: subsonic-booter-jar-with-dependencies.jar
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
LD_LIBRARY_PATH=/usr/lib/jvm/java-6-openjdk/jre/lib/amd64/server:/usr/lib/jvm/java-6-openjdk/jre/lib/amd64:/usr/lib/jvm/java-6-openjdk/jre/../lib/amd64
SHELL=/bin/bash
Signal Handlers:
SIGSEGV: [libjvm.so+0x7c9a80], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x7c9a80], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x6873c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGXFSZ: [libjvm.so+0x6873c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x6873c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x686bd0], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x689110], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGTERM: [libjvm.so+0x689110], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x689110], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
---------------  S Y S T E M  ---------------
OS:6.0.7
uname:Linux 2.6.32-5-amd64 #1 SMP Fri May 10 08:43:19 UTC 2013 x86_64
libc:glibc 2.11.3 NPTL 2.11.3
rlimit: STACK 8192k, CORE 0k, NPROC infinity, NOFILE 1024, AS infinity
load average:1.57 1.01 0.68
/proc/meminfo:
MemTotal:       16406500 kB
MemFree:        13850384 kB
Buffers:           61148 kB
Cached:          1359352 kB
SwapCached:            0 kB
Active:          1863952 kB
Inactive:         528276 kB
Active(anon):     972908 kB
Inactive(anon):     3620 kB
Active(file):     891044 kB
Inactive(file):   524656 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       3997680 kB
SwapFree:        3997680 kB
Dirty:              5164 kB
Writeback:             0 kB
AnonPages:        972412 kB
Mapped:            69588 kB
Shmem:              4292 kB
Slab:              83860 kB
SReclaimable:      68744 kB
SUnreclaim:        15116 kB
KernelStack:        2816 kB
PageTables:        25152 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:    12200928 kB
Committed_AS:    2971604 kB
VmallocTotal:   34359738367 kB
VmallocUsed:       42368 kB
VmallocChunk:   34359691196 kB
HardwareCorrupted:     0 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
DirectMap4k:        4096 kB
DirectMap2M:     2041856 kB
DirectMap1G:    14680064 kB
CPU:total 8 (8 cores per cpu, 1 threads per core) family 21 model 1 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, mmxext, 3dnowpref, lzcnt, sse4a
Memory: 4k page, physical 16406500k(13850384k free), swap 3997680k(3997680k free)
vm_info: OpenJDK 64-Bit Server VM (20.0-b12) for linux-amd64 JRE (1.6.0_27-b27), built on Jul 16 2013 13:50:11 by "buildd" with gcc 4.4.5
time: Thu Oct 17 09:21:51 2013
elapsed time: 19 seconds
I'm not an expert in java or anything else ....... :D
Question is now is this a Subsonic Problem or a Java general problem ?
Tks
Henning
henning
Re: subsonic crash
Postby daneren2005 » Thu Oct 17, 2013 4:17 pm
My best guess would be update to the latest version of Oracle Java instead of OpenJDK Java.
Re: subsonic crash
Postby henning » Fri Oct 18, 2013 5:28 am
the best guess was good enough :D I upgraded for Java 7 and now it seems to work. I hope it's stable now again
Tks
Henning
henning
Re: subsonic crash
Postby feisar » Wed Jan 01, 2014 10:52 am
I just hit this problem too running Debian 7 with java-6-openjdk. All had been fine, now Subsonic just crashes after start up with the following error:
#  SIGBUS (0x7) at pc=0x00007f5f02a710b4, pid=2555, tid=140046056457984
# Distribution: Debian GNU/Linux 7.1 (wheezy), package 6b27-1.12.6-1~deb7u1
# C  [libc.so.6+0x1200b4]  __nss_hosts_lookup+0xe104
Same thing happens when I use java-7-openjdk:
#  SIGBUS (0x7) at pc=0x00007f15a75af385, pid=2388, tid=139731000256256
# JRE version: 7.0_25-b30
# Java VM: OpenJDK 64-Bit Server VM (23.7-b01 mixed mode linux-amd64 compressed oops)
# V  [libjvm.so+0x628385]  _Copy_arrayof_conjoint_jlongs+0x35
# An error report file with more information is saved as:
# /tmp/hs_err_pid2388.log
I have been reluctant to use Sun's Java because my server is publically accessible and keeping Sun's Java updated is a pain (nowhere near as easy as getting security updates from the Debian repos).
What do others do regarding keeping Sun's Java up to date?
I do run Apache as a reverse proxy in front of Subsonic, will that help against Java vulnerabilities?
feisar
Re: subsonic crash
Postby feisar » Thu Jan 02, 2014 4:33 pm
Apologies, SubSonic works fine with java-6-openjdk. The issue I had was due to a full /var partition.
feisar
