Subsonic starts but does nothing
Postby mcfanda » Sat Oct 19, 2013 4:35 pm
Just installed on an Ubuntu machine (I've done several install on other machines with no problem). Subsonic process starts and stays there doing nothing (consumes 1% of cpu, 2% of memory, ports not listed in netstat, no web access).
subsonic is 4.8 debian
java is
OpenJDK Runtime Environment (IcedTea6 1.12.6) (6b27-1.12.6-1ubuntu0.12.04.2)
OpenJDK 64-Bit Server VM (build 20.0-b12, mixed mode)
lauch is
java -Xmx512m -Dsubsonic.home=/var/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=9090 -Dsubsonic.httpsPort=9393 -Dsubsonic.contextPath=/ -Dsubsonic.defaultMusicFolder=/home/subsonic/Music -Dsubsonic.defaultPodcastFolder=/var/music/Podcast -Dsubsonic.defaultPlaylistFolder=/var/playlists -Djava.awt.headless=true -verbose:gc -jar subsonic-booter-jar-with-dependencies.jar
no error or exeptions in the logs. The subsonic.log says nothing (really empty). the subsonic_sh.log no error
any idea?
mcfanda
Re: Subsonic starts but does nothing
Postby daneren2005 » Sat Oct 19, 2013 5:51 pm
Install Oracle Java instead of OpenJDK
Postby elmastero » Sun Nov 24, 2013 7:53 pm
Same problem here.
It was working a few days ago and just stopped.
Just upgraded from 4.6 to 4.8 too.
Going to try the fix suggested above. Thanks.
Doing this: http://www.webupd8.org/2012/01/install- ... u-via.html
elmastero
Postby elmastero » Sun Nov 24, 2013 8:00 pm
OK....so I installed Oracle Java.
Still doesn't work. Same error message, etc.
Trying a reboot.
elmastero
Postby elmastero » Sun Nov 24, 2013 8:04 pm
Trying a reboot.
Didn't work. Big bummer.
What do I need to do? This used to work beautifully.
(Ubuntu 12.04)
elmastero
Postby elmastero » Mon Nov 25, 2013 2:47 am
jonnymnemo wrote:I don't know about the comments, but you can keep the users (with their password) and their settings.
They are kept in the subsonic.script file
1. stop subsonic service
2. rename the subsonic/db directory
3. start subsonic service : a new database is created.
4. open the old subsonic.script file (in the directory you renamed)
5. select the lines you want to keep (INSERT INTO MUSIC_FOLDER VALUES... INSERT INTO USER VALUES... INSERT INTO USER_ROLE VALUES ... INSERT INTO USER_SETTINGS VALUES ...)
6. in your subsonic webpage, replace "index.view" with "db.view"
7. paste the selected lines
Now you should have your old user settings
I did that. Found it here: viewtopic.php?f=2&t=10326
....and I'm back in action.
elmastero
