Web player, can't access folders and music
Postby tenpointwo » Sun Oct 20, 2013 3:29 am
I ran into this error and found I was running subsonic with Java 7 so I installed Java 6 but I still get the same error. I appreciate all of your time and any help you can give me!
Problem Description: I am unable to access my music folders and listen to the songs. When I try to access my folders and files, I get a Java TransientDataAccessResourceException (stack trace is in a code block at the end of the problem description). When I refresh the browser or restart the subsonic service, I'm able to look around a few folders before I get the Java error described earlier. When I can look through the folders, I can queue up songs, but unable to play them (when I click the play button, the song starts and ends instantly and no song is downloaded).
Stack trace   org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
   at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:71)
   at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:135)
   at net.sourceforge.subsonic.service.MediaFileService.checkLastModified(MediaFileService.java:128)
   at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:105)
   at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:79)
   at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:140)
   at net.sourceforge.subsonic.service.MediaFileService.getParentOf(MediaFileService.java:161)
   at net.sourceforge.subsonic.controller.MainController.getAncestors(MainController.java:223)
   at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:92)
Caused by: java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
   ... 65 more
Troubleshooting Steps: Restarted the service; reinstalled subsonic; installed java 6; deleted and re-added media folders.
Playback Application and version: Problem occurs both in browser ( Chrome Version 30.0.1599.101 ) and the Android application ( Subsonic Music Streamer v3.8 )
Subsonic Version: 4.8 (build 3434) – April 17, 2013
Server Version: jetty-6.1.x, java 1.6.0_27, Linux (122.0 MB / 210.9 MB)
Hardware Platform: Linux, 3.8.0-31-generic #46-Ubuntu SMP x86_64 x86_64 x86_64 GNU/Linux
Java Memory Limit: 512MB
Problem Filename: all files and folders are affected.
Output from ffmpeg -i: N/A
Last ten log file lines:
[10/19/13 1:51:12 PM PDT]   INFO   DaoHelper   Checking database schema.
[10/19/13 1:51:17 PM PDT]   INFO   Schema47   Database table 'media_file' not found. Creating it.
[10/19/13 1:51:17 PM PDT]   ERROR   DaoHelper   Failed to initialize database.
[10/19/13 1:51:17 PM PDT]   INFO   VersionService   Resolved local Subsonic version to: 4.8
[10/19/13 1:51:18 PM PDT]   INFO   PlayerDao   Deleted 2 player(s) that haven't been used after Tue Aug 20 13:51:18 PDT 2013
[10/19/13 1:51:18 PM PDT]   INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Sun Oct 20 03:00:00 PDT 2013
[10/19/13 1:51:18 PM PDT]   INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Sat Oct 19 13:56:18 PDT 2013
[10/19/13 1:51:21 PM PDT]   INFO   NetworkService   Successfully forwarding port 4040.
[10/19/13 1:56:18 PM PDT]   INFO   PodcastService   Starting scheduled Podcast refresh.
[10/19/13 1:56:18 PM PDT]   INFO   PodcastService   Completed scheduled Podcast refresh.
[10/19/13 2:51:24 PM PDT]   INFO   NetworkService   Successfully forwarding port 4040.
I'm not sure how to proceed and would like help with this issue to get the server back up and running. I have a suspicion it might be some sort of database issue since I can access the folders (but not songs) whenever I restart the service or refresh the browser and then after a few accesses it gives me the Java error described above.
-tenpointwo
tenpointwo
Re: Web player, can't access folders and music
Postby tenpointwo » Sun Oct 27, 2013 3:05 am
bump.
Does anyone have any idea what I can do about this? If not, anyone I can ask directly for help about this problem?
-tpt
tenpointwo
Postby alphawave7 » Sun Oct 27, 2013 3:28 am
S1000 errors often refer to a corrupt database, which can be caused by java updates while SS is still running. Stop SS service, and try deleting the subsonic.data file in c:/subsonic/db, but some have success deleting the entire db folder and then restarting SS.
Postby tenpointwo » Sun Oct 27, 2013 7:17 am
alphawave7 wrote:S1000 errors often refer to a corrupt database, which can be caused by java updates while SS is still running. Stop SS service, and try deleting the subsonic.data file in c:/subsonic/db, but some have success deleting the entire db folder and then restarting SS.
Thanks, that's definitely fixed my problem. After I did what you said by stopping the subsonic service and then going to /var/subsonic/db/ (I'm on Ubuntu), I deleted the whole thing and then restarted the service. Initialized the database fresh again with all my music and everything is a-okay.
Thanks again for all the help!
tenpointwo
Re: Re: Web player, can't access folders and music
Postby alphawave7 » Sun Oct 27, 2013 4:11 pm
Great news..thanks for reporting back! Cheers!
Sent from my Nexus 4 using Tapatalk
