Problems with new VLC
Postby RussMeyer » Tue Sep 16, 2008 5:14 pm
I just downloaded the newest VLC media player version 0.9.2 and it crashes when I try to play music through Subsonic. It seems to work ok when I connect to Radio Paradise MP3 streams which is also a M3U stream. The old version of VLC worked fine. Any ideas why this new version doesn't work?
edit I am running version 3.4 (build 530) of Subsonic
RussMeyer
Postby abelour » Thu Sep 18, 2008 6:59 am
After upgrading to VLC 0.9.2 I've also got problems. The stream starts and lasts for about two seconds before it stops... (My player don't crash, it just stops to stream)
Subsonic version 3.5.beta1 (build 561)
abelour
Postby bluetooth » Mon Sep 22, 2008 3:16 pm
Same with me. I decided to downgrade VLC and all is well again.
paid Subsonic user
bluetooth
Postby OutrightLie » Wed Sep 24, 2008 11:45 pm
I was having this problem on 3.5b1. I resolved it by giving the remote player control over the stream. The downside to this is that if you add a song to your playlist you need to reload the stream in the player. It works great if you already got an established stream, or if you don't mind doing this every time you add a song.
1. Go To: Settings > Players
2. Select your player
3. Check the box that says "Playlist is managed by player"
4. Click Save, and reload the stream.
OutrightLie
Postby braddyo » Mon Sep 29, 2008 8:14 pm
I have the same problem, and the solution posted by OutrightLie works for me. I wonder if this is a problem with VLC or Subsonic. The M3U files look fine though, so I doubt it's Subsonic.
braddyo
Postby braddyo » Mon Sep 29, 2008 8:15 pm
Now playing: Paloalto - Fade Out/In
via FoxyTunes
braddyo
Postby RussMeyer » Wed Oct 01, 2008 8:01 pm
I'm letting Cool Player handle my M3U files for now. It's a nice little music player. I still like VLC for video files.
RussMeyer
Postby abelour » Thu Oct 02, 2008 11:06 am
Giving the remote player control over the playlist solved my problem. And it also made me aware of functionality I did not know about, this makes Subsonic even more perfect :)
Thanks for the tip!
abelour
Postby djiest » Fri Oct 17, 2008 6:54 pm
From time to time I get occasional drop outs, which interrupt the music. Very annoying. The solution mentioned before does not resolve the issue, I too have the latest VLC, by which the playlist is managed.
I'm not seeing any drop outs in the status screen.
I'm using Subsonic 3.5.beta2 (build 666)
Any ideas anyone?
PS: I love Subsonic :)
djiest
