Service Auto-Start Fails
Postby jps2041 » Tue Nov 05, 2013 5:04 pm
Anytime I reboot my computer the subsonic service needs to be started manually even though the settings within the subsonic control panel as well as the windows service titled subsonic is set to automatically start when the computer boots up.
After some messing around I was able to figure out a temporary work around.. "temporary" has turned into several months because I don't have a clear solution. The workaround is to use the windows task manager to kill any subsonic service process on the machine, go into the program files area and open the "booter jar with dependencies" jar file .. and when that is done loading run the subsonic-agent-elevated as administrator then it seems to work.
This is very annoying, and causes problems if my computer automatically restarts from updates or something.
Anyone got any ideas?
License Subsonic Premium
Version 4.8 (build 3434) – April 17, 2013
Server jetty-6.1.x, java 1.7.0_40, Windows 7 (87.5 MB / 520.0 MB)
jps2041
