*.subsonic.org redirecting to wrong address
Postby flvinny521 » Tue Nov 05, 2013 8:49 pm
I've set up subsonic a few separate occasions, most recently to reinstall my OS. I've set it up once again with all my usual settings, but when attempting to use my external subsonic.org address, I am redirected to an IP which I don't recognize at all. As a result, I am unable to connect to my server from outside of my own network.
How can I force this redirect to be refreshed, or better yet, manually set the IP in order to access my server from anywhere?
flvinny521
Postby Dr_FUBAR » Thu Nov 07, 2013 7:49 am
I don't think is possible to force the IP
Sent from my INO_ONE using Tapatalk
Dr_FUBAR
Re: *.subsonic.org redirecting to wrong address
Postby gurutech » Thu Nov 07, 2013 2:10 pm
Set up a No-IP or DynDNS account and choose a domain that fits what you are trying to do (ie, "servemp3.com" or something similar), and create your hostname, then use a "port 80 redirect" to port 4040 and pull in your IP address.
Some routers will allow you to configure No-IP or DynDNS into the router so your IP will be updated automatically, while others will require the download of a small utility to run on your computer to do this for you.
gurutech
Postby flvinny521 » Thu Nov 07, 2013 7:49 pm
Thanks for the tip, gurutech. For now I used the far less elegant way of just registering a new address and switching all my clients' server info one by one. A new *.subsonic.org address redirected perfectly where it was supposed to go.
flvinny521
