Issue with Subsonic and Google's 'Play Music' app
Postby ali » Thu Nov 07, 2013 9:50 am
When playing music downloaded from Subsonic through the Google Play Music app, the seekbar does not work and I'm not able to seek (fast forward or rewind) the song playing. The counter also just displays --:-- and does not work.
Is this a known bug? Is there a fix for it?
Device: LG Nexus 5
ali
Re: Issue with Subsonic and Google's 'Play Music' app
Postby daneren2005 » Thu Nov 07, 2013 3:11 pm
That has nothing to do with Subsonic and is the Play Music app's problem ;)
Postby ali » Tue Dec 03, 2013 4:39 am
Thanks for the feedback (and your awesome app), but there just has to be a better answer to this. Play Music on the Nexus 5 gets amazing battery life compared to any other music player, primarily due to the N5's DSP tunneling chip. Also, it would be nice to see ALL the music on my device in a single app.
In my testing, I've noticed that simply moving a song to another folder then back fixes this for that album. So if you have an album with 10 songs, and you move just 1 to another folder like /Music then back, the entire album start to work correctly in Play Music. I've checked the permissions in Solid Explorer and they don't seem to be the culprit.
ali
