Upgrade Help
Upgrade Help
Postby jarrodarmstrong » Sun Nov 10, 2013 1:05 pm
Never fails, whenever I upgrade my Subsonic server I have to spend days running down issues. Either that or upgrade the app and it doesn't work with the server. Then have to upgrade the server and spend days running down issues.
Here is my error after upgrading to 4.8, I have a Quad Core Win 7 Computer with 8GB of Ram, memory shouldn't be an issue:
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; out of memory; nested exception is java.sql.SQLException: out of memory
Java version Sun Microsystems Inc. 1.6.0_25
Server jetty-6.1.x
Memory Used 35 of 190 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; out of memory; nested exception is java.sql.SQLException: out of memory
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
at net.sourceforge.subsonic.dao.MediaFileDao.getMediaFile(MediaFileDao.java:59)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:103)
at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:145)
at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:61)
at net.sourceforge.subsonic.controller.LeftController.getMusicFolderContent(LeftController.java:220)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:142)
Caused by: java.sql.SQLException: out of memory
... 65 more
jarrodarmstrong
Re: Upgrade Help
Postby jarrodarmstrong » Sun Nov 10, 2013 1:27 pm
Never mind, I forgot that I usually have to delete a recreate the db, really dumb that I have to do that. Thanks Sindre.
jarrodarmstrong
