http error 503 service unavailable
Postby ffammeree » Sun Nov 10, 2013 4:34 pm
Subsonic server has running correctly since 1 year ago. But now all connections are rejected with an error "http error 503 service unavailable".
Hereafter logs.
the only changes I can suspect is the "JAVA 7 Upgrade 45" occured a few days ago AND/OR the upgrade to subsonic 4.8
Can you help me please.
Many thanks.
Fred.
---Agent----
28 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@32efa7: display name [org.springframework.context.support.ClassPathXmlApplicationContext@32efa7]; startup date [Sun Nov 10 17:17:42 CET 2013]; root of context hierarchy
78 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-agent.xml]
333 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@32efa7]: org.springframework.beans.factory.support.DefaultListableBeanFactory@cbb612
345 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@cbb612: defining beans [service,agent,frame,settingsPanel,statusPanel]; root of factory hierarchy
Executing: subsonic-service.exe -start
----Service----
A part of log is deleted at the begining (because message size)
setting bean property 'parsers' with key [1]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#fcc74c' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error c:\subsonic/db/subsonic.backup java.util.zip.ZipException: incorrect header check
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'metaDataParserFactory' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot create inner bean 'net.sourceforge.subsonic.service.metadata.FFmpegParser#fcc74c' of type [net.sourceforge.subsonic.service.metadata.FFmpegParser] while setting bean property 'parsers' with key [1]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#fcc74c' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error c:\subsonic/db/subsonic.backup java.util.zip.ZipException: incorrect header check
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:230)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:117)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedList(BeanDefinitionValueResolver.java:287)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:126)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
... 59 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#fcc74c' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error c:\subsonic/db/subsonic.backup java.util.zip.ZipException: incorrect header check
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:219)
... 74 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error c:\subsonic/db/subsonic.backup java.util.zip.ZipException: incorrect header check
... 82 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error c:\subsonic/db/subsonic.backup java.util.zip.ZipException: incorrect header check
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1338)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
... 95 more
Caused by: org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error c:\subsonic/db/subsonic.backup java.util.zip.ZipException: incorrect header check
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:577)
at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:71)
at net.sourceforge.subsonic.dao.PlayerDao.deleteOldPlayers(PlayerDao.java:132)
at net.sourceforge.subsonic.service.PlayerService.init(PlayerService.java:56)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1414)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1375)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335)
... 105 more
Caused by: java.sql.SQLException: File input/output error c:\subsonic/db/subsonic.backup java.util.zip.ZipException: incorrect header check
at java.sql.DriverManager.getConnection(Unknown Source)
... 119 more
2863 [main] ERROR org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@be922{/,jar:file:/C:/Program%20Files/Subsonic/subsonic.war!/}
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'mediaFileService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'metaDataParserFactory' while setting bean property 'metaDataParserFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'metaDataParserFactory' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot create inner bean 'net.sourceforge.subsonic.service.metadata.FFmpegParser#fcc74c' of type [net.sourceforge.subsonic.service.metadata.FFmpegParser] while setting bean property 'parsers' with key [1]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#fcc74c' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error c:\subsonic/db/subsonic.backup java.util.zip.ZipException: incorrect header check
... 59 more
... 74 more
... 82 more
... 95 more
... 105 more
... 119 more
2867 [main] WARN org.mortbay.log - Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'mediaFileService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'metaDataParserFactory' while setting bean property 'metaDataParserFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'metaDataParserFactory' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot create inner bean 'net.sourceforge.subsonic.service.metadata.FFmpegParser#fcc74c' of type [net.sourceforge.subsonic.service.metadata.FFmpegParser] while setting bean property 'parsers' with key [1]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#fcc74c' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error c:\subsonic/db/subsonic.backup java.util.zip.ZipException: incorrect header check:
2888 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
2915 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
3918 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
3938 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[169.254.104.69:9412](local),objID:[0:0:0, 0]]]]
ffammeree
Re: http error 503 service unavailable
Postby MaynardWaters » Wed Apr 02, 2014 9:39 pm
I am also getting a 503 Error:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/index.view
Powered by jetty://
Will follow up with logs and such.
MaynardWaters
Postby MaynardWaters » Wed Apr 02, 2014 9:51 pm
I am in the irc freenode #subsonic channel, if anyone wants to chat.
on ubuntu
16:47 < MaynardWaters> I think it might be caused by a java update
16:49 < MaynardWaters> update-java-alternatives -l
16:49 < MaynardWaters> shows version 6, so I don't think that is the problem
16:49 < MaynardWaters> I've updated to the latest version of subsonic I could
download, but not yet a nightly build
MaynardWaters
Postby msujdog » Fri Apr 04, 2014 2:34 am
I am also having this problem.
msujdog
Postby GJ51 » Fri Apr 04, 2014 2:30 pm
Most likely due to upgrading Java without first shutting down the Subsonic service. If the upgrade doesn't first shutdown the application, it probably corrupts the database and throws it into an unsolvable state thus generating the 503 error.
Postby jflorance » Sat Apr 05, 2014 10:43 pm
I have the same 503 issue. Just happened an hour ago after a restart. I've noticed issues this the index for a few weeks, probably about the same time Java 7_b51 showed up. I'm sure it's a database issue but how do I recover from this? I tried all the suggestions I found in the forum including uninstalling Java and Subsonic and reinstalling both.
jflorance
Postby GJ51 » Sun Apr 06, 2014 1:00 am
Did you delete the Subsonic data directory - On windows C:\Subsonic?
Postby jflorance » Sun Apr 06, 2014 1:37 am
I did not delete the C:\subsonic folder. Should I?
Edit: I am on windows.
jflorance
Postby GJ51 » Sun Apr 06, 2014 2:43 am
The 503 error results from corruption to the database stored in the C:\Subsonic directory. When you re-install Subsonic it looks for the directory and if there it just re-uses the bad database and you get the same result. Clearing the C:\Subsonic directory forces the installation program to reinitialize a clean database instance.
You will lose all your data, but that's what happens if you don't do an occasional backup. If you did back up the data directory before you started having problems, you can recopy the backup to C:\Subsonic to restore the data.
To avoid a recurrence it's a good idea to make a backup of the data directory at least once a week.
This problem results whenever the database isn't properly closed by the file system of the underlying Operating System. That can be caused in more than one way, such as an abrupt shutdown, power failure, hardware failure. Operating system update that doesn't shut down affected services during the update.
I've seen this happen in a lot of instances related to Java updates as the update routine has a rather nasty lag time where the user might think the update has either failed or already conclude when it is still running in the background. Whenever you do a Java update, it's best to stop the Subsonic service until the update is finished and verified successful.
HTH
Postby jflorance » Sun Apr 06, 2014 4:47 pm
Gary,
Thank you for the detailed description. I went to a backup copy and it was also corrupted. I started from scratch and everything is back. Took about 30 minutes to reconfigure everything.
Here are a few observations/questions:
1. I did not re-install Java 1.7b51. I left it at 1.6. I wonder if there is any downside to not using the latest version.
2. I have a couple of odd messages in the log:
[4/6/14 11:05:51 AM CDT] INFO VersionService Resolved latest Subsonic final version to: 4.9
[4/6/14 11:05:51 AM CDT] INFO VersionService Resolved latest Subsonic beta version to: 4.9.beta4
I had run the beta and then upgraded to 4.9 but am not sure what is going on here. Just prior to my crash & burn I noticed the indexing seemed to choke on a podcast with an invalid wrapper (or something like that). That podcast is not in my folders. I think it may have been a video with an mp3 extension.
3. Is there an easy way to recover podcasts and playlists?
I should have tackled all this 30-60 days ago when I noticed odd things going on with the database. Not sure what I could have done to prevent my trainwreck. A backup of bad data is still bad data Maybe a good house cleaning every year or so is a good thing :-)
We should add your post to the wiki so I know where to find this next year when the next java update kills my db.
Thanks for your help,
John
jflorance
Postby GJ51 » Mon Apr 07, 2014 3:40 am
In all honesty, most of what I've been able to learn about 503 errors has come from helping others. I'm sure I've run into it once or twice. but it's been several years since I last encountered it on one of my servers. I use Outlook on my desktop and have a bunch of sticky notes there with details I collect about Subsonic. I would recommend that you do some form of note taking for yourself as it can get hard to find specific information you've read several years ago here in the forums even using good search phrases.
I'm not sure what the current latest Java version is, but I've always just install whatever was the latest release and did updates when available. Some time ago I noticed that the Java update process to a long time where the installation process didn't generate any active screen messaging to indicate that it was in progress. Depending on your download and processing speeds, I began to think that some users were not letting the Java installation/update to complete before rebooting the system and corrupting the update. I think the same dynamic might be at play with Windows updates on occasion as I get a lot of people running XP machines that bring me their systems telling me they're all messed up, only to find that automatic updates are just bringing these older systems to their knees. When I connect their systems to my fios 35/35 internet and let the installations run, everything runs fine. LOL - an easy $50 thank you.
It's not possible to determine remotely what happens with each individual 503 crash, but I think it safe to assume that it's related to premature/improper shutdowns that don't let the db close files properly.
As far as playlists and podcasts, I don't do much with that stuff unless I go on a road trip. That's the only time I set up a playlist or two for travel. I wouldn't worry too much about the log version messages. I doubt they have any significance for operation.
Finally, if you do search 503 errors there are tons of historical discussions on the topic.
Postby jflorance » Mon Apr 07, 2014 4:43 am
This all makes sense. My problem was probably compounded by a router on it's last leg. I just figured that out this weekend and will be replacing it. It probably messed with both Java and Windows updates.
John
jflorance
