Subsonic and Server Sleeping
Postby Shadaki85 » Wed Nov 13, 2013 11:53 pm
Hello, i've set up a Subsonic Server on my machine. The problem is that my machine is set to sleep in 3 min and i can't find an option in Subsonic to prevent sleeping when i'm streaming music or video. do you know how to solve this problem? Is there a way to reset the sleep timer when streaming? i can't figure it out and having to WoL it every 3 mins is a bit... frustrating :)
P.S.: I know about power options, but i NEED to set my machine to sleep in some mins if not used.
Thanks in advance
Shadaki
Shadaki85
Re: Subsonic and Server Sleeping
Postby alphawave7 » Thu Nov 14, 2013 6:02 am
Subsonic requires constant drive access to remain available. A cloud service would be more appropriate to your needs.
Postby Shadaki85 » Thu Nov 14, 2013 7:24 am
accessing one time a day (maybe less) 13,4GB of files? :)
i'd prefer setting Subsonic up correctly...
anyway...i know that it has to access the disk... i'm asking if there is a way to prevent the machine's idle state with subsonic or some kind of application..
Shadaki85
Postby Shadaki85 » Sun Nov 24, 2013 4:15 pm
Any help? :/
Shadaki85
Postby alphawave7 » Sun Nov 24, 2013 7:20 pm
Shadaki85 wrote:Any help? :/
Look into solid state drives?
Postby ripley » Mon Nov 25, 2013 3:50 pm
The issue here I believe is use case. Subsonic is a music server. By design servers are usually on all the time. If you need your machine to sleep then running a server on it is probably not the best idea.
Why does your machine need to sleep? Have you looked at alternative options? Another PC? A Raspberry PI and a USB Harddrive?
ripley
Postby Shadaki85 » Thu Nov 28, 2013 4:16 pm
I need to put it into sleep mode because it is too much power-consuming... Using subsonic a couple times a week makes it unconvenient...
Anyway, i'm writing a small program in C# to prevent standby when a certain port is used (4040 in this case).
So when subsonic is streaming content, standby timer is stopped.
If someone is interested i'm gonna post it somewhere when done..
Shadaki85
Postby Shadaki85 » Mon Dec 02, 2013 10:34 pm
program is ready, i'll test it a bit next days.
if someone is interested, pm me
Shadaki85
