xxx.subsonic.org returned HTTP error code 404 Not Found
Postby machinehunter » Wed Nov 20, 2013 12:55 am
Problem Description: I can no longer access my subsonic server using the subsonic.org redirection address. Subsonic says myservername.subsonic.org returned HTTP error code 404 Not Found in the Settings-> Network section when I click SAVE.
Troubleshooting Steps: Restarted server, reset modem, reset Router, Tried DMZ, Checked port forwarding with http://www.canyouseeme.org/ and got a success on port 8080, Searched the forums and found similar problems but no solutions that worked for me. Read the Getting started section.
Playback Application and version: Android/web browser/anything. (none work)
Server Version: jetty-6.1.x, java 1.7.0_45, Windows 7 (78.7 MB / 115.5 MB)
Subsonic Version: 4.9.beta2 (build 3636) – November 16, 2013 (This problem started with the server running beta1 and I tried the upgrade to see if that would fix it)
Hardware Platform: Windows 7
Java Memory Limit: 1024 mb
Problem Filename: None that I know of.
Output from ffmpeg -i: I'm not really sure if this is relevant.
Last ten log file lines:
11/19/13 4:18:51 PM PST]   INFO   DaoHelper   Checking database schema.
[11/19/13 4:19:13 PM PST]   INFO   DaoHelper   Done checking database schema.
[11/19/13 4:19:15 PM PST]   INFO   VersionService   Resolved local Subsonic version to: 4.9.beta2
[11/19/13 4:19:18 PM PST]   INFO   MediaScannerService   Automatic media library scanning scheduled to run every 7 day(s), starting at Wed Nov 20 03:00:00 PST 2013
[11/19/13 4:19:19 PM PST]   INFO   UPnPService   Starting UPnP service...
[11/19/13 4:19:19 PM PST]   INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Nov 19 16:24:19 PST 2013
[11/19/13 4:19:20 PM PST]   INFO   UPnPService   Disabling UPnP/DLNA media server
[11/19/13 4:19:20 PM PST]   INFO   UPnPService   Starting UPnP service - Done!
[11/19/13 4:19:29 PM PST]   INFO   NetworkService   Successfully forwarding port 8080.
[11/19/13 4:19:59 PM PST]   INFO   VersionService   Resolved latest Subsonic final version to: 4.8
[11/19/13 4:19:59 PM PST]   INFO   VersionService   Resolved latest Subsonic beta version to: 4.9.beta2
[11/19/13 4:22:19 PM PST]   INFO   NetworkService   Successfully forwarding port 8080.
[11/19/13 4:24:19 PM PST]   INFO   PodcastService   Starting scheduled Podcast refresh.
[11/19/13 4:24:19 PM PST]   INFO   PodcastService   Completed scheduled Podcast refresh.
[11/19/13 4:31:14 PM PST]   INFO   NetworkService   Successfully forwarding port 8080.
[11/19/13 4:41:21 PM PST]   INFO   NetworkService   Successfully forwarding port 8080.
machinehunter
Re: xxx.subsonic.org returned HTTP error code 404 Not Found
Postby philip550c » Wed Nov 20, 2013 1:18 am
I think the service is down as that part of my servers isnt working as well but it has been for most of the year until today.
philip550c
Postby machinehunter » Wed Nov 20, 2013 1:23 am
Oh, Thanks.
machinehunter
Postby Underclocker » Wed Nov 20, 2013 2:02 am
I'm experiencing the same issue, philip is probably correct that the service is down. I tried logging in through the ___.subsonic.org redirect about an hour ago and it failed, so it has been down for at least that long.
Underclocker
