Problem with LDAP (AD) and Subsonic 3.5b1
Postby OutrightLie » Wed Sep 24, 2008 11:26 pm
Hi Sindre and others!
First thank you so much for your great work on this app.
I have an Active Directory for my home and family to use to log in across the computers. I am trying to implement Subsonic with LDAP support.
The problem I am running into is that I have specified all the values, but I am still unable to log in. I wrote a small program in C# and I can run that and get results back using the same bind user, filter, and LDAP string. However when I try to log into subsonic using that user, it doesn't work.
I have tried reloading Subsonic from the Tomcat manager, and restarting Tomcat altogether. Tomcat is running on the same machine that is the active directory server and is also the same computer where I ran my test C# program.
I can't find any logs being generated by Tomcat on the local computer. The only thing I can find is in the Subsonic help section - "[9/24/08 7:18:55 PM EDT] INFO SubsonicLdapBindAuthenticator Failed to authenticate user 'andrew' in LDAP."
Let me know if there is anything you need me to try.
Andrew
OutrightLie
Postby sindre_mehus » Thu Sep 25, 2008 4:51 am
Please locate and post error details in c:/subsonic/subsonic.log.
Postby OutrightLie » Mon Sep 29, 2008 6:18 pm
Sorry for the delayed reply. I have been messing with Gentoo on my laptop - and I think we all know how that can turn out. Sindre - here is the log entry you requested.
[2008-09-24 19:41:19,227] INFO SubsonicLdapBindAuthenticator - Failed to authenticate user 'andrew' in LDAP.
org.acegisecurity.ldap.LdapDataAccessException: LdapCallback;[LDAP: error code 32 - 0000208D: NameErr: DSID-031001BF, problem 2001 (NO_OBJECT), data 0, best match of:
]; nested exception is javax.naming.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-031001BF, problem 2001 (NO_OBJECT), data 0, best match of:
]; remaining name ''
   at org.acegisecurity.ldap.LdapTemplate$LdapExceptionTranslator.translate(LdapTemplate.java:295)
   at org.acegisecurity.ldap.LdapTemplate.execute(LdapTemplate.java:128)
   at org.acegisecurity.ldap.LdapTemplate.searchForSingleEntry(LdapTemplate.java:246)
   at org.acegisecurity.ldap.search.FilterBasedLdapUserSearch.searchForUser(FilterBasedLdapUserSearch.java:119)
   at org.acegisecurity.providers.ldap.authenticator.BindAuthenticator.authenticate(BindAuthenticator.java:71)
   at net.sourceforge.subsonic.ldap.SubsonicLdapBindAuthenticator.authenticate(SubsonicLdapBindAuthenticator.java:54)
   at org.acegisecurity.providers.ldap.LdapAuthenticationProvider.retrieveUser(LdapAuthenticationProvider.java:233)
   at org.acegisecurity.providers.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:119)
   at org.acegisecurity.providers.ProviderManager.doAuthentication(ProviderManager.java:195)
   at org.acegisecurity.AbstractAuthenticationManager.authenticate(AbstractAuthenticationManager.java:45)
   at org.acegisecurity.ui.webapp.AuthenticationProcessingFilter.attemptAuthentication(AuthenticationProcessingFilter.java:71)
   at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:252)
   at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
   at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
   at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:36)
   at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
   at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
   at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
   at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
   at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
   at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
   at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
   at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
   at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
   at java.lang.Thread.run(Thread.java:619)
Caused by: javax.naming.NameNotFoundException: [LDAP: error code 32 - 0000208D: NameErr: DSID-031001BF, problem 2001 (NO_OBJECT), data 0, best match of:
   at com.sun.jndi.ldap.LdapCtx.mapErrorCode(LdapCtx.java:3030)
   at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2951)
   at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2758)
   at com.sun.jndi.ldap.LdapCtx.searchAux(LdapCtx.java:1812)
   at com.sun.jndi.ldap.LdapCtx.c_search(LdapCtx.java:1735)
   at com.sun.jndi.ldap.LdapCtx.c_search(LdapCtx.java:1752)
   at com.sun.jndi.toolkit.ctx.ComponentDirContext.p_search(ComponentDirContext.java:394)
   at com.sun.jndi.toolkit.ctx.PartialCompositeDirContext.search(PartialCompositeDirContext.java:376)
   at com.sun.jndi.toolkit.ctx.PartialCompositeDirContext.search(PartialCompositeDirContext.java:358)
   at javax.naming.directory.InitialDirContext.search(InitialDirContext.java:267)
   at org.acegisecurity.ldap.LdapTemplate$3.doInDirContext(LdapTemplate.java:249)
   at org.acegisecurity.ldap.LdapTemplate.execute(LdapTemplate.java:126)
   ... 38 more
OutrightLie
Postby NeilYoung » Wed Nov 05, 2008 7:15 pm
Sounds like you got a non-existent DN specified in the "User Search field". Seems like the string is empty :?:
NeilYoung
