Cannot Access Server on LAN from iPhone
Postby jdawg5600 » Wed Nov 27, 2013 3:31 am
When I am connected to Wi-Fi on my home network, I cannot connect to the server from my iPhone using the public address http://name.subsonic.org
When I turn off Wi-Fi, I have no problem connecting to the server from my iPhone using the public address.
If the server is hosted on my LAN, I am confused as to why I cannot access it using my iPhone which is on the same LAN. I use iSub, I think what I need to do is hit the local IP of the server when I'm on Wi-Fi but I don't see a way to add another server which is essentially the same server, just want to use the private IP instead of the public.
Please help!
jdawg5600
Re: Cannot Access Server on LAN from iPhone
Postby gurutech » Wed Nov 27, 2013 4:00 am
The DNS server is resolving your server name to the IP address of your phone instead of the IP Address of your server. It's a known issue. The only workaround is to create your own DDNS account (such as DynDNS or No-IP), and use that when you are on your home network.
Alternatively, you can just use the IP address of your server in isub.
gurutech
