subsonic domain not found after working successfully
Postby luciomagano » Sat Nov 30, 2013 6:54 pm
I tried some procedures that others users posted as "solved" on this forum, but without success. Here is what I've found in the log after "uncheck" - "save" - "check" - "save" my subsonic address on the "network" settings:
[2013-11-30 15:31:03,427] WARN NetworkService - Failed to create port forwarding.
java.lang.Exception: null: Error: Current state of service prevents invoking that action. Connection error or no response received.
at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMappingImpl(ClingRouter.java:116)
at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMapping(ClingRouter.java:89)
at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:150)
at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:307)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:439)
at java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:317)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:150)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$101(ScheduledThreadPoolExecutor.java:98)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.runPeriodic(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:204)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
at java.lang.Thread.run(Thread.java:695)
I appreciate any help. Thanks
luciomagano
Users browsing this forum: Google [Bot] and 17 guests
