Subsonic Internal Error
Postby seankthx » Sat Nov 30, 2013 9:43 pm
I have to reboot my server that is running subsonic about once a day and even more often now because it gives me this error:
http://i.imgur.com/9WAY6dZ.png
If I do not hard reset the box and just do a "service subsonic restart" it gives me a page with this:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/index.view
Powered by jetty://
Server is running Debian 6:
Linux 2.6.32-5-amd64 x86_64 GNU/Linux
java -version
java version "1.6.0_27"
OpenJDK Runtime Environment (IcedTea6 1.12.6) (6b27-1.12.6-1~deb6u1)
OpenJDK 64-Bit Server VM (build 20.0-b12, mixed mode)
Last couple of lines from /var/subsonic/db/subsonic.log:
DISCONNECT
/*C194994*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C194995*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C194996*/SET SCHEMA PUBLIC
CONNECT USER SA
SET AUTOCOMMIT FALSE
SET AUTOCOMMIT TRUE
DISCONNECT
/*C194997*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C194998*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C194999*/SET SCHEMA PUBLIC
CONNECT USER SA
SET AUTOCOMMIT TRUE
DISCONNECT
/*C195000*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C195001*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C195002*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C195003*/SET SCHEMA PUBLIC
CONNECT USER SA
DELETE FROM PLAYLIST WHERE ID=0
INSERT INTO PLAYLIST VALUES(0,'seankthx',FALSE,'Nov 8, 2013 7:28 PM',NULL,0,0,'2013-11-08 19:28:52.292000000','2013-11-30 16:37:59.736000000',NULL)
SET AUTOCOMMIT TRUE
DISCONNECT
seankthx
Users browsing this forum: Google [Bot] and 17 guests
