Subsonic not responding
Postby bluetooth » Thu Oct 02, 2008 1:01 pm
Using the latest beta, I have noticed subsonic stops responding after a number of hours, usually the next day.
I reboot the PC, and it is up again. I am using the windows service option of SS.
If there is something I can do to help track down this problem, please let me know.
paid Subsonic user
bluetooth
Postby sindre_mehus » Thu Oct 02, 2008 1:13 pm
When that happens, can you please check if the subsonic.exe process is running or not.
If it's not running, you can look for files called hs_err_pidxxxx.log in c:\program files\Subsonic. If there are any (with timestamps that match), then the Java VM has crashed. The Java VM version is logged in these files, please make a note of it. Upgrading to the latest Java version (Java 6 update 7) might fix the problem.
Postby bluetooth » Thu Oct 02, 2008 1:52 pm
I will update Java and then monitor for possible hangs after that.
paid Subsonic user
bluetooth
