Can't access server!!!!
Postby gemx » Fri Dec 06, 2013 10:53 pm
My free trial expired, so I then paid for a year subscription to premium.
After paying for the year I then typed my subsonic address in and it still says my trial has expired and I need to pay to upgrade!
I've tried opening subsonic with my start menu to which it brings up local host and says http error: 404, not found.
I really would like to be able to access my server seen as I've paid a year subscription and cannot enter my license key!!
HELP.
gemx
Re: Can't access server!!!!
Postby alphawave7 » Sat Dec 07, 2013 4:04 am
Reboot the server, then retry opening from the system tray icon-Open in browser, which will verify the server has started.
Postby gemx » Sat Dec 07, 2013 2:16 pm
alphawave7 wrote:Reboot the server, then retry opening from the system tray icon-Open in browser, which will verify the server has started.
This did not work , still says not found
gemx
Postby GJ51 » Sat Dec 07, 2013 3:46 pm
gemx wrote:My free trial expired, so I then paid for a year subscription to premium.
HELP.
Interesting -
If the server is responding from the Subsonic address to tell you the trial period has expired then the server is running and you are probably not typing the correct localhost address.
Try using localhost:port# in your browser.
Postby gemx » Sun Dec 08, 2013 5:00 pm
HELP.
Interesting -
I am typing the correct subsonic address in.
No joy with localhost:port# just directs me to a google search :(
gemx
Postby GJ51 » Sun Dec 08, 2013 5:19 pm
Are you attempting this on the Server? This will only work when you are logged onto the host machine.
It doesn't make any sense that the server can generate the error msg. that the license is expired, but that it is not running. Is the associated service running on the host machine? What OS are you running? Which version of Subsonic d you have installed.
If in fact Subsonic is not running on the host machine, then you'll have to reinstall it. The license key should still be valid once you get Subsonic running properly.
When you can't access Subsonic for whatever reason, the first step is to log onto the host machine and attempt to access it from the browser on the local machine. If that doesn't work then check to see if the Subsonic service is running. Try a manual start if the service has stopped. If that doesn't work then you most likely will find it easiest to just do a re-install.
Postby gemx » Sun Dec 08, 2013 9:38 pm
GJ51 wrote:Are you attempting this on the Server? This will only work when you are logged onto the host machine.
I've used the same machine the whole time. Windows 7 and Subsonic 4.8.
Subsonic service is running. Will delete and re-install to see if that gives any joy!
gemx
Postby GJ51 » Sun Dec 08, 2013 10:16 pm
In theory you should be able to just rerun the setup exe. You might as well try the 4.9 beta 2 while you're at it.
It's not a bad idea to make a backup of C:\Subsonic before you do anything else.
