Messed up Library
Messed up Library
Postby bluetooth » Sun Oct 12, 2008 1:20 pm
I've messed up my library. This is not a subsonic, but quickly: I moved the library to my nas drive, but quickly realized this will not be feasible until I install a gb adapter in the subsonic PC.
I moved back to the local library location, and now things just don't want to update correctly.
Question: Which files can I delete so the library is recreated from scratch?
Cliff
paid Subsonic user
bluetooth
Postby bluetooth » Sun Oct 12, 2008 3:03 pm
Doing some more troubleshooting, it looks like albums with existing ratings don't appear in the highest rated category. Removing and re-rating albums doesn't seem to have any effect.
However, interesting the stars do appear when the album is displayed. So somehow this connection has been corrupted.
Any suggestions how I might rebuild the ratings, or which files to remove so Subsonic can start again?
paid Subsonic user
bluetooth
Postby sindre_mehus » Sun Oct 12, 2008 7:09 pm
Did you place the files in the same directory as before? If so, you should try to do "Settings > Search > Update search index now" and see if that helps.
Postby bluetooth » Sun Oct 12, 2008 8:27 pm
The music went from:
e:\music
to
z:\music
now back to
e:\music
I guess I could blow away the entire subsonic directory, but I'd rather just remove the db that has the ratings. Or maybe this isn't possible?
paid Subsonic user
bluetooth
Postby sindre_mehus » Mon Oct 13, 2008 4:59 am
Did you try to update the search index? This process also takes care of missing/reapparing files.
For instance, if a rated album is moved from e: to z: it will be logically deleted from the database. If it later reappears (is moved back to e: ) if will be logically undeleted.
Anyway, to reset the database you can delete the c:/subsonic/db directory.
Cheers,
Postby bluetooth » Sat Oct 18, 2008 2:30 pm
Yes, I tried rebuilding the index with no success.
I decided to blow away the db directory, and it is working again. All the ratings, configured podcasts, internet radio and comments are gone but it's working.
paid Subsonic user
bluetooth
