Transcoding problem
Transcoding problem
Postby DM-UK » Wed Sep 20, 2006 10:54 pm
I've only just come across this application, and so far it seems to be very nice, I do however have a big problem with it :(
I am using apple lossless files, which I transcode with a command line utility. I have managed to compile and get it working properly on windows, so far I have sucessfully integrated apple lossless with the Jinzora jukebox.
The issue (I've not done much with java - so its a bit of a guess) is the stdin/stdout mode. When I was first compiling the source (http://craz.net/programs/itunes/alac.html) I had to alter the file mode to binary for stdin/out otherwise any files output from the command line would only be static.
I assume that during the transcode in java that there is a non binary stream somewhere, I am using the same settings and execubles to transcode via stdin/out with php. This uses alaccommand | lamecommand with an exec().
I'm not quite sure how to work it out, so if any ideas are welcome.
David
DM-UK
Postby sindre_mehus » Thu Sep 21, 2006 7:23 am
Hi David,
It's a bit unclear to me whether it worked or not after you changed stdin/stdout to binary. Also, it seems to me that binary mode is supposed to be used on Windows. From main.c:
#ifdef WIN32
    setmode(fileno(stdout), O_BINARY);
    setmode(fileno(stdin), O_BINARY);
#endif
Anyway, if you only get static noise, it's most likely wrong byte order (little-endian vs big-endian). Did you try to add the "-x" option to LAME? It swaps the byte order.
By the way, I only use binary streams in the Java transcoding engine.
Hope this helps,
Postby DM-UK » Thu Sep 21, 2006 8:15 am
oops!
I've just noticed that when I reused the default m4a setting I forgot to remove the -x from the lame command line! :oops:
Problem solved :)
David
DM-UK
