Subsonic on Vista
Subsonic on Vista
Postby HiSpeed » Mon Oct 27, 2008 11:48 am
I have problems installing Subsonic 3.5 beta2 on Vista.
Du you have a guide?
HiSpeed
Postby selkov » Tue Oct 28, 2008 1:59 am
what issues do you have?
selkov
Postby HiSpeed » Tue Oct 28, 2008 9:34 am
I have used windows installer 3.5.beta2 and I can not get Subsonic to work. Only a blank screen (http://localhost/) and no icon in the system tray.
HiSpeed
Postby selkov » Tue Oct 28, 2008 1:51 pm
As vista shows no Icon you need to be sure first that the service is running.
Go to the start bar and enter service.msc.
Look down the list to see if the service (subsonic) is installed and if it is running. If it is not running or not installed go to the start bar/ all programs/ find the subsonic folder and choose start subsonic server.
Then try to connect via local host.
Remember to open a firewall access rule for subsonic IF you will be accessing from the outside internet
selkov
Postby HiSpeed » Tue Oct 28, 2008 2:02 pm
The Subsonic services are running.
Blank screen on http://localhost/ on LAN (same PC with subsonic services)
HiSpeed
Postby selkov » Wed Oct 29, 2008 9:35 pm
No Browser errors?
page not found?
404?
Etc?
Did you open ports in the firewall/
Do you have a popup blocker or antivirus?
selkov
Postby HiSpeed » Thu Oct 30, 2008 11:52 am
selkov wrote:No Browser errors?
page not found? No
404? No
Etc? Nothing I now about
Did you open ports in the firewall/ Yes - 8080
Do you have a popup blocker or antivirus? AVG
HiSpeed
Postby selkov » Fri Oct 31, 2008 2:50 pm
My path would be as follows:
uninstall subsonic
change router to point to another port [8080 is to common] try 9000
disable avg
reinstall subsonic
point it to the new port
open firewall port if not
run subsonic and see if you connect.
ps if you changed the port correctly http:\\localhost will not work unless it is like this:
http://localhost:9000
PS I sent you a PM...
selkov
Postby HiSpeed » Sat Nov 01, 2008 11:27 am
I changed the port to 9000 and then subsonic started :D
Thx to selkov
HiSpeed
