WINDOWS HOME SERVER
WINDOWS HOME SERVER
Postby phloyd » Thu Nov 13, 2008 6:30 pm
Can this program be run with Windows Home Server? If so, how about a detailed tutorial on how to do it.
If not (or even if so), what are the prospects of their being an add-in made available for Windows Home Server?
Also, just need a clarification. Will Subsonic stream itunes songs purchased from the itunes store?
phloyd
Subsonic runs on WHS
Postby sofisten » Tue Nov 25, 2008 6:00 pm
I've been running Subsonic on my Windows Home Server for a couple of days now, and this runs verry well! I'm lovin' it.....
Ther's one issue tough:
You will have to change the port on subsonic, because the default port (p.80) is in conflict with the ISS on the WHS. I'm running on port 81 and this works fine.
You might have trouble from some offices and so, because the firewall are only opened for port 80 and 443.
I'v been searching for way to have IIS run subsonic, but with no luck so far. I'll post a separate tread for this.
sofisten
Port 8080 and 8081 will work
Postby sofisten » Wed Nov 26, 2008 5:47 pm
Hi again,
As you see from the thread about subsonic on IIS http://forum.subsonic.org/forum/viewtopic.php?t=1395 both port 8080 and 8081 usually works.
sofisten
